Old 04-15-2012, 03:16 PM   #1
mike73
mike73's Avatar
Parts Interchange help!!!!!
What I've got; 1973 short/fleet.... 3 on the tree, no a/c,disc brakes (not power)
1984-1986 c-10 van.......
73 has a shotty 305
What im shooting for;
350/350 swap from van into c-10
Power Disc Brakes
Parts im hoping interchange;
Radiator
Steering column
Brake pedal assembly
Master cylinder/brake booster
Sway bar
Wheels
Possibly rear end
Transmission crossmember
If I've left something out don't hesitate to let me know..... Im going for the engine/transmission swap,the automatic conversion, and the power Disc brake upgrade..... Help,comments,suggestions......anything to help me avoid problems up ahead.....
mike73 is offline   Reply With Quote
Old 04-15-2012, 05:20 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Parts Interchange help!!!!!
the motor and trans will go right in.. Im reasonably certain its the same power booster that would be there in the pickup. I dont think the pedals will work but i could be wrong but for the conversion you dont need to do the pedal swap.. you can just remove the clutch pedal and call it good im not sure about any of the other parts
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-15-2012, 06:04 PM   #3
Dsquared
i'm pretty sure that the steering column is gonna be too short and the van frame is wider than the truck frame. the wheels will work
Dsquared is offline   Reply With Quote
Old 04-17-2012, 05:34 AM   #4
mike73
mike73's Avatar
Ok thanks fellas!
Old 04-17-2012, 11:27 AM   #5
esbstuff
73 has a shotty 305
Power Disc Brakes
Radiator-----------------------Most possibly
Steering column---------------Not even close
Brake pedal assembly----------c above
Master cylinder/brake booster--c above
Sway bar----------------------Just might
Wheels------------------------BOLT ON
Possibly rear end---------------Nope
Transmission crossmember------Notta, But you don't need one anyway, just move your current one back....
As a side note, the brake pedal is diff from a power brake truck to a non power brake truck.
My plan would be buy the van, remove motor/trans/radiator. Sell the column to the 67-72 guys, scrap the rest and buy the correct parts you need ...
esbstuff is offline   Reply With Quote
Old 06-12-2012, 10:29 PM   #6
mike73
mike73's Avatar
Spindle --->out? Rotors /calipers /?????????
The neighborhood Dennis the menice thought it would be funny to take everyones lug nuts this past weekend.... Lost front wheels doing 60......... Glad i had rear brakes
Old 06-12-2012, 11:17 PM   #7
badpontiacs
badpontiacs's Avatar
So, what's different with the pedal from power to non power. I swapped and only had to change the push rod. No stopping issues at all. I do understand the difference from auto and manual trans pedal.
badpontiacs is offline   Reply With Quote
Old 06-13-2012, 02:46 PM   #8
HotRodScottsdale
HotRodScottsdale's Avatar
I caught a little bastard doing that in my area too,I was lucky he was only 3 years younger then me so I got my revenge for my poor neighbors and there axles.
On a quite night you can hear a ford rust
HotRodScottsdale is offline   Reply With Quote
Old 06-14-2012, 07:24 AM   #9
walkerb
walkerb's Avatar
From what Ive noticed its the throw length and the size of the hole where it connects to the pedal.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
