Re: 1991 4l80e/np205 combo question
Driveshafts will be wrong lenght now, your new trans is longer but the 205 is shorter than the.203.
Shifter hole may work if you have the 205 shifter from 1991. But you're going from the tall adapter to the short so that may change your shifter hole as well as crossmember location. 85+ its a direct swap. Posted via Mobile Device |
