06-16-2012, 01:36 AM | #1 |
cab seam question
ok guys im about to fill in my seam on top rear of the cab and i took a wire brush to get all the seam sealer out. my question is way down inside the seam there is still some stuff that actaully looks like all metal filler but not sure. can i weld over this???
06-16-2012, 09:29 AM | #2 | |
Active Member
Re: cab seam question
Some prefer to paint with good epoxy or other good quality paint first. Instructions will tell you which is better. |
06-16-2012, 06:18 PM | #3 |
My question is is it safe to weld over.
Posted via Mobile Device |
06-17-2012, 12:29 AM | #4 |
top/rear of cab. We didn't mess with it on mine, but we thought it could possibly be Lead.
Not way down inside, but the entire seam that runs across the top/back of the cab.
project: "my happy mess" |
06-17-2012, 05:39 AM | #5 |
If you're going to weld the seam,why not put a torch to it and see what happens? I would think it should be out of there for a proper weld. I'd burn it out with a torch if you can't get at it that deep.
06-17-2012, 10:05 AM | #6 |
I will echo the post above it was what was alreadt thinking before I read down that far . get a torch and heat the seam to see if it is lead. I have had it on my list of things to do but it will be a lot of work[ of course what isn't on these trucks?]
06-17-2012, 02:26 PM | #7 |
Thanks guys. Torch it is.
06-17-2012, 05:27 PM | #8 |
Take care and do not breath in the fumes.
And if you're grinding on it (if it is Lead), take caution to dust. You don't want to be touching that stuff or transmitting it into your home via clothing.
