Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-17-2012, 05:54 PM   #1
kennyhammond
just put in the 468 in the c10..need help
ok just put the big block in have a couple things to do to make it run.. first should i run a electric or mechanical fuel pump?? either or ..what size or flow numbers...then i am putting a 1050 cfm carb on it ..duel plain intake should i run a spacer?? thank you i am running a msd ignition with spark box rev limiter to 6k any info much appreciated
kennyhammond is offline   Reply With Quote
Old 06-17-2012, 05:55 PM   #2
kennyhammond
Re: just put in the 468 in the c10..need help
o one more thing where is a good place to find wiring diagrham for the ignition box so i can wire it up... picked the ignition up from a guy and have to put it back together
Old 06-17-2012, 07:44 PM   #3
chevy72blu
chevy72blu's Avatar
You dont list specs of the motor, but mechanical will likely work fine. I chose to run an electric pump because I had issues with vapor lock in the SW heat. For reliability reasons, I prefer a mechanical pump. With an electric, you will need a separate fuel pressure regulator. Give Summit a call and they will spec a pump for your motor.
You probably dont need a spacer but some motors gain a few top end HP with them. You sacrifice low end power with them. I would just go with the dual plane you have and see (cheap experiment).
As for the box diagram, MSD has VERY good instructions. Go here and type in your model number. http://www.msdignition.com/instructiondownload.aspx
chevy72blu is offline   Reply With Quote
Old 06-17-2012, 08:21 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Curious,,,, what dual plane intake have you found for a dominator ,, that's assuming a Dominator. Otherwise ,, what 1050 cfm 4150 style carb is this. I know Prosystems and Braswell make 1000cfm , and Patricks new SV1 can be had in some HUGE cfm's. but just curious why such a large cfm carb and a dual plane intake??????
and of course.,,,, why a 1050?? it really need that much CFM? just asking.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-18-2012, 12:10 AM   #5
Captainfab
60-66 Nut
I was thinking the same thing. A 1050 Dominator and a dual plane intake seem contradictory. That would have to be one healthy 468 to need a 1050. A 750 cfm carb is sufficient for most mild to moderately built 468's
Old 06-18-2012, 12:43 AM   #6
kennyhammond
The Guy I got the motor from had it built ...assured it needed that Carb...don't know the intake ...how much gph...do I need...he dynoed the motor at 700hp...was built for a mud drag truck
Old 06-18-2012, 12:14 PM   #7
rollinhard
rollinhard's Avatar
700hp is a big #. Is this running on race fuel and does it have big heads on it. Everything seems to contradict them selves. Big carb on a duel plane with a high rmp range. Your gonna need a 4500 flange open plenum for that 1050 and probably have power range in the upper rpm level. Justbrain storming here not bashing. Are you gonna use it on the street or strip
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 06-18-2012, 12:34 PM   #8
Marv D
Marv D's Avatar
Still a lot of questions here, but at face value,, for a 700 hp motor that is being ran at it's potential.... I'd not use anything less than a 250GPH pump and a QUALITY return style regulator, and an8 line. Ive ran 600-650 motors on an6 and 110gph pumps but it appears to be about the limints with data logging fuel PSI. The fuel want sto stay at the starting line on a hard launch and if your pumping all the way from the back,, fuel consumption of a real 700HP motor,,,, best to be safe rather than sorry.
Heres a page of real helpfull stuff on fuel systems.
http://www.centuryperformance.com/fu...e-spg-140.html
Old 06-18-2012, 01:45 PM   #9
kennyhammond
K I pulled the valve covers and motor has 781 heads....so I am personally thinking it doesn't have more than 550.... so sorry for the false info....
