06-18-2012, 04:20 PM | #1 |
what do you use to secure door weatherstripping?
So what sort of adhesive do I need to go get to install my weatherstripping onto my cab? I saw the 3M stuff at the auto parts store, but I vaguely remembering hearing that it's not that great and that you're better off using this green goop from Ford, or something like that.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
06-19-2012, 08:09 AM | #2 |
Re: what do you use to secure door weatherstripping?
I have used the 3M Gorilla snot many times and it is good stuff it is a little messy however so you must be prepared for that
06-19-2012, 08:28 AM | #3 |
I use the 3M stuff all the time at work, also used it on my trucks weatherstrip.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
06-19-2012, 09:01 AM | #4 |
DRYWALL SCREWS and duct tape
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
06-19-2012, 09:21 AM | #5 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-19-2012, 10:25 AM | #6 |
Why would you want to use weatherstrip? You just replaced all the cab metal. Gotta have a little water in her....haha
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-19-2012, 01:12 PM | #7 |
Senior Enthusiast
I've used the 3M gorilla snot, but I prefer the black version they also make. If any of it sneaks out around an edge, there isn't any hideous yellow residue showing. It comes in the same style red box as the yellow stuff so you have to be careful you're buying the right product.
http://3mcollision.com/3m-weatherstr...011-black.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
