Old 06-13-2012, 12:17 PM   #1
AJohn6
Knuckle head
AJohn6's Avatar
Question for the disc brake Gurus
I am getting ready to start round 2 on my '71. I just ordered a ton of parts and am now trying to make a game plan on what needs to be accomplished.
I ordered the Wilwood 13" front/rear disc brakes, Scotts Hotrods under the dash pedal assembly, remote dual reservoir and 7" booster w/ corvette style master cylinder.
My question is as follows.
What is the purpose of the coiled brake line just after the proportion block and are they needed? With an under dash assembly, as long as the master cylinder and reservoir are the highest points of the system do I need a check valve?
Thanks in advance,
Adam
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 06-13-2012, 12:21 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Question for the disc brake Gurus
I personally see no need for the coiled brake tubing.
And you are correct,... no check valve needed as long as the M/C is higher, in the chassis, than the brake calipers.
Keith
Convert to disc brakes.
Old 06-13-2012, 12:36 PM   #3
3rdGen.c10
3rdGen.c10's Avatar
the coils are for ease of doing a body lift. you just spread them out. so no theyre not needed.
1967 c10 stepside 6.0L 4L80E
3rdGen.c10 is offline   Reply With Quote
Old 06-13-2012, 12:50 PM   #4
AJohn6
Knuckle head
AJohn6's Avatar
Awesome, thanks fellas.
Hey 3rdGen.C10, I used to live down in Navarre and used to go to the track to watch my buddies race their bikes. I was stationed there for about 5 years.
Adam
Old 06-15-2012, 01:33 PM   #5
tinydb84
tinydb84's Avatar
I believe the coils increase flexibility and prevent the lines from cracking
Old 06-15-2012, 02:28 PM   #6
cdowns
cdowns's Avatar
yes and i would use them for a prolonged trouble free lifespan of sure stopping
Old 06-18-2012, 09:43 PM   #7
CRGRS 66
CRGRS 66's Avatar
the purpose of these coils is to absorb vibration and to allow for some movement without breaking or stressing the lines causing premature failure. in the process I have seen some make them look real pretty too, bending and routing hydraulic lines can be an art form
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 06-19-2012, 01:35 PM   #8
AJohn6
Knuckle head
AJohn6's Avatar
Great info guys, thanks. That what I figured it would be but I just wanted to make sure.
Adam
Adam
Old 06-19-2012, 03:35 PM   #9
robnolimit
robnolimit's Avatar
The coils from the OE were there to allow some movement of the master without cracking the lines. The under dash unti you'r using will flex a little - so I would either coil the hardline, or use a flex line from the master over to a bulkhead fitting on the firewall. You will need an adjustable proportioning valve to adjust the front/rear bias, and I recomend a 2lb check valve in both the front and rear line.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 06-19-2012, 06:51 PM   #10
AJohn6
Knuckle head
AJohn6's Avatar
Rob,
Thanks for the help. It's guys like you, the ones that really know what they are doing, that make this forum the best I've found. I have spent the last 3 day reading your "Make it handle" thread and it is blowing my mind. Just the shear volume of valid information you give out for free is amazing. I know I appreciate and I'm fairly certain others on this site do to.
Thanks,
Adam
Adam
Old 06-20-2012, 12:39 AM   #11
robnolimit
robnolimit's Avatar
No problem. Make it fun to drive, and you'll drive it more
