![]() Join Date: Jul 2010
1971 4x4 Blazer Frame
Selling my spare '71 4x4 frame which previously belonged to Kurt Linder (VTBlazer) in Vermont. The frame was POR15d a few years ago and is in good shape. Very little to no rust. Just needs to be cleaned up a bit. Right now it has dust all over it so the pics aren't great. But it's a good solid frame. As seen in one of the pics below, Kurt drilled an additional set of holes for the motor support in order to move the motor forward a bit. Trans crossmember support and motor crossmember support are included. They're in solid shape too, but they show a little wear. The two rear-most leaf spring mounts were removed from the frame to accomodate a 1st Gen Shackle Flip (which I have for here… http://www.67-72chevytrucks.com/vboa...d.php?t=519868 …for $125). So new ones will need to be bolted on.
Asking $500 for frame and crossmembers. ![]() ![]() ![]() ![]() ![]() ![]()
Re: 1971 4x4 Blazer Frame
New price = $400
ttt
$350
One last shot or I have to take this thing to the scrap yard. It's taking up valuable space in my driveway. New price = $250.
Just a nother gear head
just move it out back and hold on to it just in case. would hate to see a good frame get scrapped.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
Good idea. I just didn't want to sit on it though because I have received ZERO interest on it. So I figured there must not be a demand.
there is alot of 4x4 frames around is probably why you got no bites. Im actually looking for a trans case coss memeber if you ogot an extra?
I could sell the one in the pic above. Will that work? What do they go for? Maybe I'll sell the cross members and mounting brackets off…
I think I have an extra.. Does not have the sections that go the top rail of the frame though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
im not sure what they go for. cant imagine its more than 50 bucks. it will work perfect. if you will do $ 50 shipped i will take it.
Did not see the cut til I scraped it a bit and one mount hole is blown out. Not sure what it is from but measures the same width (33") as my 72 and 70 seems to be a little higher mounting but I lower mine anyway to get better clearance and angle on the driveshaft.
get a quick weight and call ups. shipped to 03825. if its going to be more than 75 including memeber its not worth it to me. i build one for under 50.
#15 |
Do you still have the rear spring hangers (front of rear axle) Let me know if you would be willing to sell them.
#16 |
The Waco Kid
Do you still have the engine crossmember? Price shipped to 76705? Thanks, Greg
#17 |
| Bookmarks |
