Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 06-20-2012, 08:04 PM   #11
robnolimit
robnolimit's Avatar
Re: No Limit Spy Photos
1) We use a Romic billit coil-over. They have worked with us for years to get the valving set correctly for the weight balance of a truck, not the average camaro. The lower mount is a 'trunion'. - These coilovers are display units, built to be at 'Ride Hieght'. The IFS will come with 5" stroke shocks, 12" - 17" and 12" springs. 2) The upper coil-over mount is part of the crossmember. 3)This is how get the track width without the bumpsteer. 4) The custom machined rack extension installs on the PASSENGER side only. Use red locktite. The factory rack boot will cover it just fine. 5) Bolt in the rack and tie-rod ends.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
