Old 06-07-2012, 05:42 PM   #76
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: The Wagon and Pedal Car thread.
Lookin' good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-07-2012, 09:52 PM   #77
hgs_notes
GEARHEAD
hgs_notes's Avatar
I got an idea in my head about a year ago for a wagon I wanted to build. This thread got me to start putting it together. I have fabbed up every part so far except the wheels and tires. It's not done yet and I won't show the whole thing until it is, but here's a teaser pic:
hgs_notes is offline   Reply With Quote
Old 06-07-2012, 10:37 PM   #78
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Ohhh... I like what I see so far.
-Nate
Old 06-14-2012, 02:00 AM   #79
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This is what's left of mine from the mid 60's
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-15-2012, 08:13 PM   #80
doubleb's69
doubleb's69's Avatar
Here are some more pics of mine. The pic without the wood is before spindles. Just trying to see how it was going to look. The other two are as a roller with everything burned in. When I take it back apart for paint I will take pictures of the the frame I built. Also there is one satin red wheel and thats how they all will look when done. It has just a slight amount of rake to it. I wanted more but the nature of the tires does not allow it. The axle is welded at the lowest point possible on the spindles. I wasn't crazy about the rear wheels and tires because I thought they were to big untill I got the fronts on and It made it proportional, now I think it looks awesome.
Bud
doubleb's69 is offline   Reply With Quote
Old 06-15-2012, 09:39 PM   #81
hgs_notes
GEARHEAD
hgs_notes's Avatar
Very cool.
Old 06-16-2012, 07:48 PM   #82
hgs_notes
GEARHEAD
hgs_notes's Avatar
I got a couple rod ends I had ordered so I could finish up my suspension. I made a couple brackets and now I have a track bar that functions perfectly, and it's adjustable. I also swapped out the springs because I found some bigger ones at the swap meet last weekend. Now it won't bottom out the trailing arms to the frame.
I'm still working on the wagon box part.
Old 06-16-2012, 10:30 PM   #83
hgs_notes
GEARHEAD
hgs_notes's Avatar
Not done yet, but I couldn't wait to share.
This is the bed for my "wagon". It's just roughed in at this point. I made it about 1/2 scale of a real shortbed, except narrower. The sides and rear panels are made with 3 layers of plywood. I just got the tailgate part roughed in tonight. Cutting that slot across it was the most challenging part of the build so far. The last parts to fab up are the wheel tubs. I haven't decided yet if I will shape them like the real ones or just make some round ones. I will blend in the contours and body lines with body filler, epoxy primer it all to seal it, then do the body work like a real truck. I plan on painting it to match my truck. The floor will be stained plywood with bed strips added (once I find a couple to cut up). If I find better wheels with slightly smaller tires later I will probably swap them. For now I think I will paint them with some chrome like paint I have and maybe try to add white lettering to the tires. I'm thinking about using a caster wheel under the front near where the handle will go. My wife has a craft paper cutter and I'll have her make me some lettering for the tailgate.
Trailing arm...
Attachment to the bracket I made...
Crossmember for my spring support and to add some rigidity to the frame...
Axle attachment to the trailing arm, with spring installed...
Chassis...
Old 06-17-2012, 11:12 AM   #84
doubleb's69
Looks sweet!
Bud
Old 06-20-2012, 09:23 PM   #85
doubleb's69
Here is some more progress on my wagon. All I have to do is thread the axle ends paint the frame and wheels, and polish the aluminum pieces going on it.
Bud
Old 06-21-2012, 01:58 AM   #86
broey
Square
broey's Avatar
its coming along awesomely! is it pretty heavy?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 06-22-2012, 09:08 PM   #87
doubleb's69
Yes, if you are talking to me. I think it will be around 40 to 50 pounds without the kid in it. I could be way off but it gets old putting it on the welding table and then taking it back off every time I work on it especially with the wood in the bed.
Bud
Old 06-28-2012, 05:53 PM   #88
doubleb's69
It is finished for this year. There will be modifications in the future. I would like to thank forum member SBORIS for giving me the wear strips for free including delivery from about an hour away while he was headed to work.
Bud
Old 06-28-2012, 07:51 PM   #89
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks great! I hope mine turns out as nice.
Old 06-28-2012, 08:27 PM   #90
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
It looks great Bud!
Ryan
1969 Chevy milk truck
Old 07-16-2012, 08:23 AM   #91
sboris
sboris's Avatar
Bud, that turned out awesome. Love the color, and of coarse the strips "set it off"
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 07-16-2012, 07:48 PM   #92
theastronaut
theastronaut's Avatar
Anyone know anything about this one? I rode the wheels off of it as a kid, and never have seen another one like it.
theastronaut is offline   Reply With Quote
Old 07-18-2012, 08:51 PM   #93
broey
Square
broey's Avatar
I think black hornet is the brand. they made chain driven tractors also. I see those pedal cars every so often at antique stores but they always want way too much for them.
Old 07-20-2012, 09:40 AM   #94
5150
C10 Club Tennessee
5150's Avatar
Finished Lizzy's pedal stroller yesterday. Going to add a removable pole on the seat that I can stick an umbrella that I modified in for shade.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-20-2012, 10:25 AM   #95
hgs_notes
GEARHEAD
hgs_notes's Avatar
I don't think I have ever typed the word 'cute' on this board, but, well, there it is.
Old 07-20-2012, 11:07 AM   #96
Graham57a
Graham57a's Avatar
Hey Bryan that steering wheel looks great, glad it worked out for you
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 07-26-2012, 01:03 PM   #97
5150
C10 Club Tennessee
5150's Avatar
Thanks Graham
She finally got to use it this weekend at the Southeastern Truck Nationals. Here's a pic of my buddies that I saw at last years show and gave me the inspiration.
Bryan
www.gmtruckshow.com
Old 07-26-2012, 02:29 PM   #98
doubleb's69
Turned out awesome Bryan. Looks like she had more fun than she could handle.
Bud
Old 08-05-2012, 05:30 PM   #99
nds1968
nds1968's Avatar
Here is my BEER Wagon. I made it haul coolers full of beer for JITH http://www.jamboreeinthehills.com/
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 08-05-2012, 05:33 PM   #100
nds1968
nds1968's Avatar
Some pics of the underneath
Nate
