Old 06-21-2012, 01:28 PM   #1
BlueEK9
BlueEK9's Avatar
How low is too low? (Static Drop)
I recently did a 5.5" static drop on the front of my 67. I used CPP 2.5" spindles, 3" DJM springs, Porterbuilt shock relocators and 235/60/15 tires up front. My control arms are aproximately 2" off the ground. I had to trim them a little to accommodate the 15" rims and CPP drop spindles. I love the way it looks but I am constantly bottoming out. Should be concerned about damaging my control arms or some other suspension components? The sway bar brackets on the control arms are only an 1.5" away from hitting the upper spring cups.
If you are on Facebook check out our group.
northwestc10s@groups.facebook.com
Chris Fowler
BlueEK9 is offline   Reply With Quote
Old 06-21-2012, 01:45 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: How low is too low? (Static Drop)
Too low for me with that wheel/tire package.
Looks really good but I would be afraid I would destroy the truck on every bump/driveway or rail road track.
With my 4.5" front drop and 20" wheels I never rub and my x member is nowhere near that close to the ground.
you can buy shorter/low profile sway bar frame mounts
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 06-21-2012, 01:49 PM   #3
leftcoast66
leftcoast66's Avatar
It shouldn't be an issue, but it all depends on your driving style. Watch for bumps and avoid them, go slowly when needed, and you'll be ok.
leftcoast66 is offline   Reply With Quote
Old 06-21-2012, 02:11 PM   #4
Cole Trickle
C-10 Club Member
lol.... he lives in WA and is parked on gravel
Old 06-21-2012, 02:19 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Buy some control arms as spares and enjoy it.
KQQL IT is online now   Reply With Quote
Old 06-21-2012, 02:30 PM   #6
BlueEK9
BlueEK9's Avatar
Cole, what size tires are you running up front with your 20's? I have a set that I'm getting ready to buy tires for.
Chris Fowler
Old 06-21-2012, 03:03 PM   #7
Cole Trickle
C-10 Club Member
20x8.5 255/40/20 (F)
20x10 295/40/20 (R)
Old 06-21-2012, 04:22 PM   #8
1971_402
1971_402's Avatar
WOW.. I got CPP 3in drop springs on mine and it no ware near that drop.. And mine still have the Factory bump stops just without the rubber stop. What Brand are those just for curiosity sake.
1969 Chevy C10 Shortbox SB/TH350(SOLD)
1971 GMC Sierra Grande BBC(SOLD)
1972 Chevy C20 Longbed SBC/4Speed(Sold)
1972 Chevy C10 LWB-SWB/Bagged(ALMOST)
1972 Chevy C10 Shortened/SBC(DONE)
1981 Chevy C10 SWB 383/TH350(SOLD)
1971_402 is offline   Reply With Quote
Old 06-21-2012, 05:38 PM   #9
BlueEK9
BlueEK9's Avatar
3" DJM springs, CPP 2.5" drop spindles and 26" tall tires.
Chris Fowler
Old 06-21-2012, 06:36 PM   #10
502ms
502ms's Avatar
I agree with the comments above re: drive it, enjoy it.
I ride lower than that daily.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 06-21-2012, 07:08 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Your truck looks Sweet!
Adding a Porterbuilt Mild Dropmember or Pro Touring Dropmember will give you more ground clearance, at the same ride height.
Keith
Convert to disc brakes.
Old 06-21-2012, 08:17 PM   #12
shawno72
C/10 junkie
shawno72's Avatar
I like it!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 06-21-2012, 09:12 PM   #13
Gus350
68 C 10
Gus350's Avatar
Would just adding porter built control arms with stock cross member give it anymore ground clearance.
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-21-2012, 10:44 PM   #14
Narxoleptic Customs
Screw it, drive the crap out of it. Ull be okay.
Narxoleptic Customs is offline   Reply With Quote
Old 06-22-2012, 12:51 AM   #15
jwalk
What was I thinking?
jwalk's Avatar
Your truck looks good! I like how it sits!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 06-22-2012, 12:58 AM   #16
gringoloco
A guy with a truck
gringoloco's Avatar
Tube arms and a taller tire- or do the PBDM, if you have the $. Truck looks sweet, but if you catch one of those arms on something, you might/will destroy it. I've seen frames folded like origami...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-22-2012, 01:30 AM   #17
cory d
cory d's Avatar
the truck looks great. i think it might really help if you baged the front, you look like you would sheve the heads of the bolts on I5
cory d is offline   Reply With Quote
Old 06-22-2012, 02:06 AM   #18
BlueEK9
BlueEK9's Avatar
I appreciate all the feedback. Is anyone else running the same/similar set up? I'll most likely just leave it the way it is and take it easy. Porterbuilt stuff is great but I don't want to invest that much money into this truck. I'm also working on a short box that already has a complete Porterbuilt setup.
Chris Fowler
Old 06-22-2012, 07:39 AM   #19
lolife99
lolife99's Avatar
Not really.
The "pivot point" of the lower a-arm is still the closest thing to the ground.
It will make contact first.
Keith
Old 06-22-2012, 07:41 AM   #20
lolife99
lolife99's Avatar
I am.
My red '69 has a 5.5/7.5 drop.
My a-arms are 2.5" off the ground at the lowest spot on the lower a-arms.
(I have a 7" wheel with a 215/70-15 tire)
Swapping the front coils would be the easiest answer,... but then you won't be "driving" at this low height anymore.
Keith
Old 06-22-2012, 10:13 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would try changing to a different coil. I have never had good luck with 3" coils. I would go with a stock coil cut, or a 2" drop instead.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-22-2012, 11:15 AM   #22
gringoloco
A guy with a truck
gringoloco's Avatar
Mine is a similar drop (3" spindles, 1" coils with a round cut), but I'm running a 28" tall tire to keep the arms up off of the ground and I still would like some more clearance. Seeing the devastation that is caused by hanging an arm, even at low speed, worries me...
-Chris
Old 06-22-2012, 12:08 PM   #23
Tinkermc
where I live with pot holes and rough pavement I could not do that I might go 16" tires or just taller tires and enjoy it and DRIVE IT LIKE YOU STOLE IT!!!!!!
Tinkermc is offline   Reply With Quote
Old 06-22-2012, 07:10 PM   #24
INSIDIOUS '86
INSIDIOUS '86's Avatar
Take the springs out and get some 3/4 ton or one ton springs cut for the same drop stiffer springs will keep the front from dropping so low when you hit a Gregoire hole
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-25-2012, 03:35 PM   #25
a_barth
How about sectioning the cross member? You could section it 1"-1.5" and buy 1.5"-2" drop springs. This would put you at the same ride height but raise the center of the crossmember and your control arm pivots at least an inch. Just pick up a spare crossmember, section it and swap it out. The truck SHOULD only be down for a few hours barring any unforseen issues.
a_barth is offline   Reply With Quote
