Old 06-07-2012, 01:20 AM   #1
MikeS.
MikeS.'s Avatar
Suggestions on lifting
a 63 4x4 Suburban. I'd like to lift it between 2 & 4". I've seen several pics on here of lifted trucks and Burbs. I haven't found any build threads on the subject though.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-17-2012, 12:53 AM   #2
Darren MagooGardner
Re: Suggestions on lifting
body or suspension lift?
Darren MagooGardner is offline   Reply With Quote
Old 06-18-2012, 09:53 PM   #3
MikeS.
MikeS.'s Avatar
Ya know, I don't know. Probably because I don't understand what the difference is. Ca n ya say Noob?
My goal, have the body sit higher than stock 4x4 with maybe 35" tires.
Past Master
Old 06-18-2012, 10:30 PM   #4
obijuan
Buy a 4" tough country lift basically. Best bang for your Buck. Offroad design can help tremendously. Check them out.
obijuan is offline   Reply With Quote
Old 06-20-2012, 04:31 PM   #5
72chevyk10
I built it
72chevyk10's Avatar
body lift, lifts the body of the truck off the frame. usually leading to large gaps between the bumpers and grill/tailgate. suspension lifts the frame off the axles which then all you need for a 4in lift is a steering arm correction and longer shocks. i would go with a suspension lift personally
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 06-23-2012, 09:04 AM   #6
MikeS.
MikeS.'s Avatar
Suspension is what I want, I just bought axles and suspension from an 87 Burb. Gives me disk brakes for sure and can lift easily if I decide to.
Thanks!
Past Master
