Closed Thread
Old 06-03-2012, 04:06 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Speedwarning tach dash with wiring and buzzer choose your options!!!
I am putting together a speedwarning dash with tach in it right now. Have a few options so wanted to offer them before completing...
Can be factory (nice) tach or new aftermarket
Nice original or new lens
In the extra hole I can install vac, air pressure, (both are nice originals) or a clock.
OR...
Can install a new 8K tach...only option at that point is for a clock in the extra hole as the lens for the 8K doesn't come with a provision for vac or air...
650 shipped for the s/w tach setup with good wiring and buzzer and new bezel of your choice (black or woodgrain)
750 shipped with the air pressure or vacuum gauges
775 shipped with the clock
800 shipped with an 8K rpm tach and open gauge spot like most tach dashes
925 shipped with an 8K rpm tach and a clock in the extra spot.
Payment required in advance of me building. Will be a 1-2 week estimated turn-around
paypal (as personal (payment owed) or w/ 3% fees added) or check/postal money order...or cash in person
Will post pictures of the actual s/w head and buzzer setup I will be using for this dash tomorrow. head's as nice as you will find...
VA72C10 is offline
Old 06-03-2012, 07:59 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Speedwarning tach dash with wiring and buzzer choose your options!!!
ttt
VA72C10 is offline
Old 06-05-2012, 02:31 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
ttt
VA72C10 is offline
Old 06-06-2012, 04:48 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
ttt....
VA72C10 is offline
Old 06-07-2012, 02:06 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
ttt....
VA72C10 is offline
Old 06-09-2012, 01:02 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
ttt
VA72C10 is offline
Old 06-10-2012, 11:42 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
Prices reduced.
VA72C10 is offline
Old 06-13-2012, 04:14 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
ttt
VA72C10 is offline
Old 06-13-2012, 11:34 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
ttt
VA72C10 is offline
Old 06-22-2012, 05:55 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
ttt
VA72C10 is offline
Old 06-22-2012, 06:45 PM   #11
Tinkermc
ttt
Tinkermc is offline
Old 06-22-2012, 07:54 PM   #12
tr69c10
I need a buzzer any extras
tr69c10 is offline
Old 06-23-2012, 11:29 AM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Tempting - 1) do you happen to have an OEM tach/vac lens for this build; 2) would the woodgrain bezel be modified to accept the s/w dial; 3) 80 lb oil gauge; 4) tach harness and s/w harness included? Thanks, Pete
DeadheadNM is offline
Old 06-23-2012, 02:14 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
1) was planning on using a new reproduction lens but will try to source a nice original if you prefer.
2)I can install the adjuster on the woodgrain bezel
3) yes, 80lb
4) correct style repro tach and original tested s/w harness and buzzer included
VA72C10 is offline
Old 06-23-2012, 02:15 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
only if someone doesn't want one as part of the deal. I have three s/w dashes I will be restoring and selling and 3 wiring/buzzer setups right now...
VA72C10 is offline
Old 06-23-2012, 02:21 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jonathan thanks for the reply. The setup I'd be interested in would have gauges, lens, and printed circuit all nice OEM. Would prefer OEM wiring as well. Curious if you have all these OEM pieces and if so total shipped. Pete
Old 06-23-2012, 02:40 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
I will put a wtb for the lens and check with a couple other sources. I have everything else right now. Price would be 750 shipped.
VA72C10 is offline
Old 06-23-2012, 02:53 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jonathan - If you can build it with all OEM (nice) restored gauges including your best sw face, OEM printed circuit, original tach tin, OEM buzzer/harnesses for the tach and sw, all screwed to a wood grain bezel for $750 shipped I will take it pending pics of the parts. If a nice OEM lens can be located - great but not a deal breaker. I'll pony up half up front then half when complete. I'm striving for all possible OEM components in my builds. Thanks, Pete
Old 06-23-2012, 03:43 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
The woodgrain bezels I have that are originals have some cracking on the grain. I have reproductions, but they aren't that great to be honest....they are the vinyl sticker type and the fit of the vinyl woodgrain is far from perfect.... I can get one of the nicer ones from CSM but those run 50 more than the std reproductions...
VA72C10 is offline
Old 06-23-2012, 03:53 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yeah, I was expecting a repro woodgrain bezel. I may have a better US made wood overlay. How much time would a bezel from CSM add to your build?
Old 06-23-2012, 04:44 PM   #21
VA72C10
VA72C10
VA72C10's Avatar
I will confirm on monday but probably only an extra week.
You could get the matching glovebox door at the same time for 95 extra...
VA72C10 is offline
Old 06-23-2012, 05:04 PM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Definitely interested. Sounds like $750 shipped for the cluster as I've described plus $145 for a wood grain bezel and glovebox door (woodgrain applied to the aluminum panel - not whole door) from CSM. Correct?
If so, lets see some pics of the cluster components when possible. Thanks, Pete
Old 06-23-2012, 05:40 PM   #23
70LonghornCST
Moderator
70LonghornCST's Avatar
Nice Buy!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline
Old 06-29-2012, 09:15 PM   #24
liftmeup
wow
lifted, locked, rockin
liftmeup is offline
Old 07-11-2012, 12:05 PM   #25
VA72C10
VA72C10
VA72C10's Avatar
got last of the parts in last night. Will take pictures this evening.
VA72C10 is offline
Closed Thread
