Old 06-24-2012, 01:26 AM   #4
Touchdown67
Touchdown67's Avatar
Re: what type of headers
Originally Posted by Captainfab View Post
Your best bet is using headers made to fit these trucks with a small block. Hedman #69260 are the correct ones for the '63-'66 trucks and they fit around the mechanical clutch linkage. You can also use Hedman #69090. They are designed for later model trucks, but they still fit with the '63-'66 mechanical clutch linkage. However a little trimming may be necessary as it is a bit tight with a couple of the tubes. At one time you could use Hooker #2453's, but they have since changed the tube layout, so I don't know for sure if they will still work
Does anyone have a say about the exhaust manifolds from Allstar Performance? How do they fit/perform?
Touchdown67 is offline   Reply With Quote
headers enginr
