Old 06-24-2012, 11:38 PM   #1
Dads Burb
Re: tilt columns
Parkwood, are you using a tilt column? Did you use Ididit's horn kit for the 55-68 stock steering wheel? Anything else required?
Dads Burb is offline   Reply With Quote
Old 06-25-2012, 11:30 PM   #2
parkwood
parkwood's Avatar
Re: tilt columns
Yes it was a Ididit tilt column and to use the steering wheel off a '57 truck all i had to do was spot weld a little tab on the horn ring to be able to hook up the wire from the column.
parkwood is offline   Reply With Quote
