So why did it drop so far!!!
First off, This is my first lowering experience. So... Yesterday, I installed Mcgaughy's 2.5" drop spindles with 2" drop coils and all new tie-rod ends and ball joints. (I ordered everything from Porterbuilt with a great experience.)
I first measured the truck at the top of the fender well and it measured 31.25" and after the install the same point now measure 25". I absolutely love how low it looks but was figuring only for a 4.5"-5" drop and not 6.25". Does anyone have any thought how my math does not add up? Will the front raise up after I install my CPP c-notch and axle flip? I'm a bit confused. Thanks in advance for any comments and tips on my situation. ![]() |
Re: So why did it drop so far!!!
maybe running lower octane helps.......lol
most of the kits i have bought were the same way. my dually was a 5/7 drop, and was actually measuring 6.5/8.5.....worked for me ![]() |
It looks worse because rear is so high.
Once back comes down, front bumper will raise. Just a distorted view right now. Posted via Mobile Device
Tim Road Hounds |
#4 | |
Yes, what Grumpy said. Posted via Mobile Device
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Yes, what boucher said about what grumpy said.
C/10 junkie
Agree on what they said
![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Square
+1 for what shawno72 said referring to what lostmy65 said about what boucher and grumpy said
Squarebody Syndicate |
Square
truck looks good too!
You got more than you paid for! That doesn't happen often these days!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Because you were lucky!
65 Chevy short fleet 350 5 speed, soon to be LSX powered 65 F100 short fleet 91 Heritage softail 94 Fatboy 11 Softail Deluxe [wife's bike] 13 Streetglide http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz |
Once back comes down, front bumper will raise. Just a distorted view right now. I agree..............drop the back and you have close to what your looking for
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
![]() Join Date: Feb 2011
Maybe those drop coils thought they were supporting a small block instead of that V-6.
MusicMan70 1961 GMC Suburban |
I placed a V/6 in the back of a 1990 GMC I had and it dropped a bit the engine was heavy.
#15 |
Senior Enthusiast
That is likely the answer. I’ve read the small block Chevy weighs 550-575 pounds. The GMC V6 weighs around 850 pounds, or close to 300 pounds (55%) more.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#16 |
My dad overhauled a V/6 for my friend and I tell you the pistons are big. My dad worked a GMC dealership and he said that GMC stopped making them due to they would last forever and they ate a lot of gas.
I would say a 6 speed trans would correct that problem of eating so much gas along with high gears on the rearend. Here is something that some of you guys might not know older GMC trucks had more heavy duty rearends the reason why I know is some old parts man that now is dead tried crossing over some rearend parts from a chevy truck and they wouldn't work he said GMC were made more HD im just saying what he told me. |
#17 | |
I appreciate the comments guys!
I have finally made time to drop the a$$ end to match the front. I have never attempted suspension mods this difficult, but with the help of some great friends and a few cervezas... anything can be done. I installed CPP's Heavy Duty C-Notch which seem much more difficult than it turned out. I did go the extra mile and welded all mating edges to help secure some rigidity. ![]() I also flipped the axle and welded on new larger Moser axle perches. ![]() Quote:
![]() I took a some time and sanded the cab down to get ready for some new paint. Overall... I am thoroughly digging my new stance. ![]() |
#18 |
So the GMC's came with leaf springs?
#19 |
#20 |
Learned something new. Thx
Posted via Mobile Device |
#21 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Great job on the flip kit.
The Moser axle perches are very similar to the early Camaro leaf spring perches. I would get rid of the the bolts holding the "sandwich plate" to the bottom of the spring perch. A set of u-bolts around the axle tube, would be a MUCH safer solution.
#22 |
Senior Car Nut
![]() Join Date: Jan 2008
maybe change the shock mounts, too? or did you already, I see some other holes up top?
Larry |
#23 | |
I did relocate the existing shock mounts backwards 1.25" from original location. I have not road tested more than a mile since the drop. I'm waiting for this heat wave to pass (somewhat) so I can paint the cab. |
