Closed Thread
Old 06-26-2012, 02:59 PM   #901
Jesse49chevy
Jesse49chevy's Avatar
Re: What Did You Do With Your Truck Today ?
and more pics...working on it...
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline
Old 06-26-2012, 03:00 PM   #902
Jesse49chevy
and now for some positive pics... body work ...
Semper Fi
Old 06-26-2012, 03:08 PM   #903
Jesse49chevy
ok, ill stop after these....
picked up the bed off Craigslist for $150.00
picked up the 73 Camaro front clip from Craigslist for $160.00
picked up the wire harness from Craigslist for $120.00
I picked up a LT1 w/ a 700R trans from Craigslist for 600.00
My dad is doing the body work in Laredo, TX. and I am working on the chassis at my house in Houston, TX. This is the first time I take on a project like this, it is exciting but intimidating. If anyone sees anything that i am doing wrong or that i could do different, PLEASE feel free to say something..
I intend to buy a rear end (suggestion??) by next week and decided to go with a CCP leaf spring kit (cheaper)
People, i could use some encouragement, keep in mind its only been a month....
Semper Fi
Old 06-26-2012, 08:58 PM   #904
Hot Rod Todd
Flew 600 miles to see my truck at the weekend (and to attend a rod run up there). We planned that the final bits on the truck would be done, but it didnt turn out like that, so instead of a road trip to bring it home, I flew home & will fly back up again in a few weeks time, when its all done and legal.
Early on in the build, we decided to replace the in-cab gas tank so we could get the seat back further, but looking at the design of the seat frame, I couldnt figure how we would gain much room at all.
I would prefer a bench seat if I could, so from your experiences, is the best option a middle/rear seat from a people carrier? We dont have the same selecton of US vehicles, but our roads are infested with Japanese Vans and people carriers which may be suitable in the truck.
Or I could fit up a pair of leather BMW bucket seats, but then I would have to make a console & it may not suit my 60s build style.
Any advice would be appreciated.
Hot Rod Todd is offline
Old 06-26-2012, 09:16 PM   #905
LDO
LDO's Avatar
I got some of the fuel system plumbing done on my new motor. Mocked up my alternator bracket and ran the oil system for a bit to keep things 'wet'.
Enjoy the pics!
LDO is offline
Old 06-27-2012, 05:52 PM   #906
crossfire84
crossfire84's Avatar
Just received my new 3" drop spindles today.
crossfire84 is offline
Old 06-27-2012, 06:15 PM   #907
B_Hix
B_Hix's Avatar
^^ wow!! Thats sharp - great job!
B_Hix is offline
Old 06-27-2012, 08:33 PM   #908
mknittle
mknittle's Avatar
I looked at it.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 06-28-2012, 12:30 AM   #909
OrrieG
OrrieG's Avatar
Cleaned and polished up the wheel trim rings, dug out the ac unit to get the hoses done so I can install it. Also finished up a wrought iron bench resto for my wife.
OrrieG is offline
Old 06-29-2012, 04:46 PM   #910
Chevette
Chevette's Avatar
Had to do some mods to the fenders so they'd clear the tires due to the wide rear suspension. Finally got one of the box sides on. I have to widen the box 2 1/2". Installed the steering column (C6 tilt/telescopic/paddles).
Chevette is offline
Old 06-29-2012, 06:35 PM   #911
B_Hix
B_Hix's Avatar
^^ your truck is going to be sharp!
B_Hix is offline
Old 06-29-2012, 07:34 PM   #912
mknittle
mknittle's Avatar
did the overhead welding on the risers for my upper coil-over mounts. I also got the upper and lower shock hangers tacked in place.
Mark
My GMC build.
mknittle is offline
Old 06-29-2012, 07:43 PM   #913
OrrieG
OrrieG's Avatar
Went to the ac line place. Came home and rethought what I was trying to do. Came up with a simpler solution after realizing I can just unbolt the inner fender if I ever need to pull the front clip.
OrrieG is offline
Old 06-29-2012, 10:17 PM   #914
B_Hix
B_Hix's Avatar
honestly I have done NOTHING the last cpl days - two hottest days of the year and we are in a drought, so I'm layin up like a old dog on a hot day!
'49 Chevy 3100; 350/350; 305 H.O. P/P heads; 10.5:1; 370 hp; '75 Firebird clip, rearend & steering column; 7+ year home build
B_Hix is offline
Old 06-30-2012, 05:40 PM   #915
crossfire84
Painted my motor mounts and cut the bottom of the door off, by then it was 93 outside. Closed the garage door and made some COLD ice tea.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
Old 06-30-2012, 07:04 PM   #916
waybad
waybad's Avatar
finally bolted my seat down,,
waybad is offline
Old 06-30-2012, 09:01 PM   #917
rollenhard
rollenhard's Avatar
Half Way Done With Installing The Wiring In My 50 Chevy Truck.
Lots Of Fun Especially When Your Trying To Hide It All
rollenhard is offline
Old 06-30-2012, 11:19 PM   #918
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
... made sure it was still in the garage.. 108 today here in W. KY, yea, W. KY. Wassup with that?
87Lowrider is offline
Old 07-01-2012, 08:28 PM   #919
handyhands
posted parts on craig's list.
handyhands is offline
Old 07-01-2012, 09:19 PM   #920
toolaidback
Brought the truck back to my shop, unloaded it, and went inside to dry off. 106 degrees here today!!
toolaidback is offline
Old 07-01-2012, 09:37 PM   #921
Trucknut57
Trucknut57's Avatar
After 1.5 years I finally got it started and drove it around the block. Found out I need to raise the bed about an inch to clear the shock mounts and I have to install some spacers on the rear end cause the rear tires are rubbing on the bed sides. Unfortunetly that means I have to get longer wheel studs, that sucks just when I thought I was close to getting to drive it again.
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline
Old 07-02-2012, 11:01 AM   #922
crossfire84
its 10.00 a.m. and its already 92 out side, and the garage is no better!
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-02-2012, 11:51 AM   #923
Trucknut57
Trucknut57's Avatar
Went from This:
To this:
- dcozzi
Old 07-02-2012, 12:34 PM   #924
jmlcolorado
Im cheating. I have a 1950 (It fits the year requirements of the thread) International L110.
I moved the front frame brace back about 8" to shorten the frame horns.
Bent some 5/8" bar stock into ring to create a place to pass the frame brace through.
jmlcolorado is offline
Old 07-02-2012, 02:00 PM   #925
crossfire84
WOW!!!
Closed Thread
