70-72 c20 Dana 60 w/trailing arm/panhard mount
Just curious to see if the trailing arm mounts are in the same location as the 12 bolt in a C10. Also is the panhard bar the same as in the C10.
60-66 Nut
Re: 70-72 c20 Dana 60 w/trailing arm/panhard mount
The trailing arm mounts should be in the same location. The panhard bar should be the same as typical on a '65-'72 12 bolt.
Why thank you sir.
