Old 06-20-2012, 07:24 AM   #1
2tonezu
Trying to lay the front of 62 c10 down
I've been looking on this site for awhile to find a write up on laying the front if a 62 c10 on the ground. Just got the front bagged and want to keep the drum brake and stock crossmember setup. The plan is to Z it but we're trying to make the Z as small as possible. any help or suggestions would be great thanks...
2tonezu is offline   Reply With Quote
Old 06-20-2012, 09:58 AM   #2
redneck6
Re: Trying to lay the front of 62 c10 down
cup lower arms , notch the frame that is the best i have seen on this site to do it . from what i have seen takes about 4 inches to lay crossmeber with bags . i would say cup the arms = 2-3 inches and notch the frame were cross member bolts to frame = 1.5 or so depending on how much you notch it .
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road .
09 ford f350 cc swb 4x4 6.4l , to haul the others home .
2011 chevy hhr not mine but love the milage ..
redneck6 is offline   Reply With Quote
Old 06-20-2012, 10:23 AM   #3
2tonezu
Thanks for the reply , I just made LCA with a 3 in cup. If that's all I can do to get it lower then I will be Z ing the frame for the rest Thanks...
Old 06-20-2012, 03:54 PM   #4
redneck6
yw i cant find the dudes build thread on it . but he notched the frame were the crossmeber bolts to frame . took a 2x4 box tubing and made it bridges were he was gonna notch it and then crossmember bolts to the tube . look a lot cleaner and stronger / easier to do then a z i will see if i can find the build
Old 06-20-2012, 04:01 PM   #5
chad64chevy
chad64chevy's Avatar
doesnt a 62 have the torsion bars? if so you can down them down and get is a lil lower, got any pictures??
chad64chevy is offline   Reply With Quote
Old 06-20-2012, 04:16 PM   #6
2tonezu
Torsion bars are out because I bagged the front... Now about to do the rear but I'm wanting the front to lay on the ground...
Old 06-20-2012, 04:18 PM   #7
2tonezu
Never thought about notching the crossmember wonder what I'll run into I I do that and how much lower it will go...
Old 06-20-2012, 04:22 PM   #8
redneck6
haha found it like page four lol
http://67-72chevytrucks.com/vboard/s...=478965&page=2
looks really clean and seems wouldnt have to mess with the tranny tunnel like you would with a z and engine and tranny should stay in same area hight wise .
Old 06-20-2012, 04:27 PM   #9
2tonezu
Nice find, I'm Deff goin to look into thy instead Thanks....
Old 06-20-2012, 04:52 PM   #10
losthope
losthope's Avatar
cant you pancake the front crossmember also so it sits higher around the frame instead of knotching the frame? ill see if i can find a thread for pancaking the crossmember..... or is a 62 front crossmember different?
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-20-2012, 05:00 PM   #11
losthope
losthope's Avatar
look closely at dino's crossmember on post # 143 and you can see where the crossmember center is cut out and rewelded lower so it wraps around the fram making the suspension sit higher:
http://67-72chevytrucks.com/vboard/s...=522708&page=6
ill see if i can find a better thread showing how to do it
Timmy D.
Old 06-20-2012, 05:16 PM   #12
losthope
losthope's Avatar
here you go front crossmember pancaking/sectioning 101:
http://www.captkaoscustoms.com/chopcross.html
Timmy D.
Old 06-27-2012, 04:33 PM   #13
redneck6
any updates on ur truck ??
Old 06-27-2012, 04:49 PM   #14
2tonezu
I cupped my LCA and the raised my lower ball joints up about 2 in. Now getting the wood floor out of the back so I can make a wishbone and raise the stock wood floor and stock fenders... This is a 100% low budget build and will attempt to make what I have work... Heres a pic of the LCA and the other pic is it layin next to my body drop...
Old 06-27-2012, 09:15 PM   #15
losthope
losthope's Avatar
Looks good ! Your the only only one that ive seen cup the a-arms and also step the ball joints at once, I was also thinking of doing this but didnt know how low the crossmember would be at a low ride height from the road? do you think you could get a picture or two of how the crossmember sits at different heights?
Timmy D.
Old 06-27-2012, 09:32 PM   #16
2tonezu
As it sits deflated the crossmember is about 1/2in from layin on the ground... I can air it up to stock ride height if needed so I'm not sure how low or high your tryin to drive it....
Old 06-28-2012, 06:16 AM   #17
losthope
losthope's Avatar
no thats ok.. thanks
Timmy D.
Old 06-28-2012, 10:27 AM   #18
redneck6
*****en giving new meaing to it is only metal . you cut the **** out the LCA . love it did you gusset under the ball joint notch ??
Old 06-28-2012, 11:30 AM   #19
2tonezu
Going go put a gusset in the center underneath after the new lower ball joints come in.. Wood floor is out of the back and we plan to just raise it along with the rear tubs...
