Old 06-28-2012, 02:57 AM   #1
jesse977
jesse977's Avatar
horn question?
My horn was never connected in my truck and today I tried to fix it. I have a Grant steering wheel. I changed the relay and it still does not work. How common is it for the horn not to work? I might just go to the junkyard and pick one up later this week.
jesse977 is offline   Reply With Quote
Old 06-28-2012, 08:47 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: horn question?
IIRC grant makes a horn button and kit that goes with the wheel that you have to use
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-28-2012, 09:22 AM   #3
crazeetxn
crazeetxn's Avatar
Re: horn question?
Have you checked to make sure it's getting a good ground? There's only the one wire that goes to the horn under the hood I believe.
Then yes, the horn kit for the Grants is about $20. But, you should be able to check and see if it work or not by touching the wire at the button to the nut or somewhere on the steering wheel.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 06-28-2012, 10:09 PM   #4
grs
Re: horn question?
Your horns may be good. Just take the horns off the truck. Then hook a ground wire from the battery to the horn body. Then run a wire from the hot terminal on the battery to the terminal on the horn, and see of it works.
grs is offline   Reply With Quote
