Registered Cruiser
Re: Help with fuel system design for LS1 install
Possible dumb question here, but....
If there is a fuel line and return line coming from the rails to the regulator, but there is only one "input" on the regulator, then two out (one to pump and one to return in tank), where does the return line from the fuel rail go??? Does the two lines coming from the rails need to "join" before the regulator?? First LS Swap obviously... ![]()
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#2 | |
#3 | |
Registered Cruiser
So no need for a regulator? I don't remember seeing any kind of regulator in the system?? What should the rails looks like? That would be good news, could be why I'm confused about this fuel system layout lol
Two lines off the intake or two lines off the fuel rail? , Is the second line going to the purge solenoid by chance? Can you post a pic of what you have? Be able to give you better advice that way.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 06-29-2012 at 02:07 PM. |
Hey folks,
I'll jump in with a question also. I am finishing my budget for my LS1 swap and I'd like some advice. I am running an LS1 our of an 02' F body, which I believe is the "returnless" style rail. I am buying a tank with an intake Aeromotive stealth efi pump from Boyd's. My plan is to run the feed and return lines from the tank to Vette regulator, and then a single feed line to the LS1 rail. I plan on using all braided hose for simplicity of install. Approx how many feet of line did you need? I dont have the motor yet so I cant measure. Im just doing this to finalize the spreadsheet Would this kit be a good idea, along with an extra few feet (4-5?) of -4 AN line for the return + extra straight/90* fittings? I know I will need extra -6AN fittings and clamps. http://www.summitracing.com/parts/SUM-PUMPKIT1/ I've never messed with fuel plumbing other than carbed stuff. Braided line/fittings are new to me. Last edited by chevy72blu; 06-29-2012 at 02:49 PM. |
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Top line is supply lower line is return. Regulator is in fuel rail, you don't need the vette regulator.
Just put in an order for (hopefully) all of my stuff. Man these fittings get pricey. Im sure that I am missing a few items, but I wanted to get the bulk of it and buy more fittings locally as I need them. Im running a 98 LS1 with returnless rail
Heres my list so far: WIX-33737 regulator/filter Summit SUM-PUMPKIT1 -6AN kit (20ft, includes 3 adapters, 2 straight, 1 90 and clamps) Summit SUM-230406 -4AN 6 ft kit (for return) SUM-220490 straight end (-4an for return) RUS-660060 3/8 NPT to -4AN (for return) (2) SUM-220690 straight ends (2) SUM-220687 90 ends RUS-644123 for vette filter RUS-644113 for vette filter RUS-640940 for vette filter RUS-640850 for fuel rail Anyone see any problems? |
![]() Join Date: Jan 2011
What pump are you using? If not an in line/external pump, what would be a suggestion?
Posted via Mobile Device |
#10 | |
I need to add the 87 fuel tank & sender along with the fuel pump for a 97 to this total for my 78
#11 | |
Registered Cruiser
My apologies.... off of the fuel rail. I can post pics once I get home. But I am pretty sure these are fuel rail lines. When I pulled the caps off, fuel spilled out of them... They are steel lines one on top of another, pointed towards the back of the motor... Exactly like Br3W City's first pic, post #10
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo Last edited by JNJchev77; 06-29-2012 at 05:36 PM. |
