06-29-2012, 09:18 PM | #1 |
Registered Cruiser
Re: Help with fuel system design for LS1 install
Thanks for the help fellas.... Here's a pic just to clarify what I have. I will list some part numbers for the fittings I use, in case any one else needs some help.
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
06-29-2012, 09:50 PM | #2 |
Registered Cruiser
Here are some part numbers for the "return style" fuel rails. Thanks for all the help guys!!!
Russell Performance 640850 - Russell Fuel Rail Fitting Adapters- Feed Line 3/8 Russell Performance 640860 - Russell Fuel Rail Fitting Adapters- Return Line 5/16 Russell Performance 670470 - Russell AN to Metric Adapter Fittings- each end of Walbro 255 fuel pump Summit Racing SUM-220690 - Summit Racing® Hose Ends- -6AN hose connector with female 6AN female threads Summit Racing SUM-230615 - Summit Racing® Stainless Steel Hose- 15ft hose using for feed Summit Racing SUM-230620 - Summit Racing® Stainless Steel Hose- 20ft using for return.
