Another AC Question
Seems to be more AC questions than normal the last few days. I can't imagine why.
![]() Anyway, there is a wire hanging under the dash on the passenger side of the middle with a plug on the end. To "turn on" the AC, I have to connect a jumper wire to both sides of that plug. My questions are does anybody know what that wire is supposed to plug into and where is it located so I can replace it?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
![]() Join Date: May 2010
Re: Another AC Question
I can't tell what color those wires are, but maybe the wiring diagram in this thread will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=307447 |
Lay on your back on the passenger side floor and look up behind the heat/air box and you should see a switch with a nylon plunger that is activated by a control cable. I believe that that switch will be where that plug goes.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Here is a link to a very weird/strange (classic?) thread that may also help.
http://67-72chevytrucks.com/vboard/s...d.php?t=216218 |
![]() Join Date: Feb 2011
Classic is Right!
MusicMan70 1961 GMC Suburban |
