new member & new project
I have a 1955 GMC 150 3/4 ton longbed truck that I bought this past year. I am going to convert it over to a short bed and use a mid-seventies firebird subframe that I already have. I haven't decided on the rear end or rear suspension yet. I have seen how people shorten the frames for the shortbed and it doesn't look that complicated, but was wondering if i would be better off just finding a shortbed frame to put my subframe on? Most of the suspension stuff I've seen for the rears say 1/2 ton only. What are the real differences between 1/2 ton and 3/4 ton chassis?
Re: new member & new project
Welcome! Glad to see another GMC on here. If you already have the F body subframe, do you have the 10 bolt rear from it, too? That's a common one to use to keep the bolt pattern and track width the same. Replacement 8.5" axle parts are easy to find, too. What engine are you planning?
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
![]() Join Date: Jul 2011
My 3/4 had spring helpers with a secondary perch, so this no load ride was ok. But with a load the secondary spring were engaged.
Build for my 1959 Fleetside... http://67-72chevytrucks.com/vboard/s...d.php?t=518308 |
Welcome.
Kim |
I have a 327 chevy small block and turbo 350 trans. that I'm going to use. For the rear I have a '55 chevy parts car and was thinking about using the rear from it. Wonder if the leaf springs would match up? I also have a complete jag rearend, but didn't really want to do that much fabrication.
Tags |
1955 gmc 150, 3/4 ton chassis |
