Old 07-01-2012, 12:54 PM   #1
bigunde
Rusty Rockerfeller
Need some lift help please
just picked up a 90 GMC. It has 315/75/16 tires on it. I am assuming someone cranked the torsion bars up as it sits level and rides TERRIBLE. What do i need to do to the front end to fix this as i want to keep the tires and rims on it?? HELP!!!!
bigunde is offline   Reply With Quote
Old 07-01-2012, 01:43 PM   #2
obijuan
Re: Need some lift help please
lower the torsion bars back down and put smaller tires on it.
obijuan is offline   Reply With Quote
Old 07-01-2012, 01:46 PM   #3
bigunde
Rusty Rockerfeller
Really??
Old 07-01-2012, 02:06 PM   #4
obijuan
what did you expect? you can lower the air pressure in the tires.
the right way to do it is to put a lift on it. it lowers everything so the a arms are in the right orientation.
or you can get fancy and do a solid axle swap.
Old 07-01-2012, 02:08 PM   #5
bigunde
Rusty Rockerfeller
Thats why Im asking. Need to know what kind of kit as Ive never done this before. Thanks
Old 07-01-2012, 02:15 PM   #6
obijuan
that only gives you maybe 2" of lift maybe a little more. a standard lift kit off the shelf will do it, but they start at 4" pretty much.
these are all the parts youd need.
Old 07-01-2012, 04:38 PM   #7
69GWC
Yeap install a 4 to 6" lift kit on it or smaller tires.
But its a truck its not going to ride real smooth and if it does more then likely its not going to be able to haul much.
69GWC is offline   Reply With Quote
