05-24-2012, 12:03 PM | #1 |
need some rear end help
I have a 1987 chevy R10 stepside shortbed 10 bolt in the truck now. I want to pull the rear and replace it with a 1976 C20 12 bolt.
My issues... I need to know the size of the u joint for the 10 and 12 bolt in order to make the conversion. Using the same 87 drive shaft Does anyone know the sizes off hand>? and maybe who makes a combo U joint?
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. |
05-24-2012, 01:28 PM | #2 |
Re: need some rear end help
They make a conversion joint and I know the part # has been posted on the board many times , just gotta find it....lol
1985 C10 2004 Avalanche |
05-24-2012, 04:15 PM | #3 |
I assume you know you'll have five lugs on the front, and eight lugs on the back, right? (unless you're doing something tricky with the axle shafts).
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-29-2012, 09:12 AM | #4 |
8 lug were on the 4x4. My 12 bolt is the same as the 10 bolt lug pattern.
But I am not at work scratching my head
05-29-2012, 09:34 AM | #5 |
Happy to be here
Your info is a bit confusing. You state that the 1976 12 bolt is from a C20 which would be a 3/4ton. That would be an 8 lug axle, and I don't think it would be a 12 bolt.
05-30-2012, 12:51 PM | #6 |
Its a 12 bolt. I am sure of that. I just never looked at the hubs.
I am not going to use it since I just bought new 5 lug rims.
05-30-2012, 04:09 PM | #7 |
Well I took a look at the studs. Its a 5 lug 12 bolt.
05-30-2012, 08:26 PM | #8 |
Thats a half ton rear end then, a little stronger than the ten bolt but not a whole lot. They should both have 1310 u joints.
06-01-2012, 12:48 PM | #9 | |
Really... that would be GREAT !!! I am using the 12bolt since it has the gears and the locker already in it. I installed it in the last truck I had .
06-29-2012, 12:12 PM | #10 |
Can anyone help me locate information on the 12 bolt rear? I do not have the old u joint anymore and NAPA can not cross these to the 10 bolt.
1976 1/2 ton 12bolt 5 lug going in 1987 1/2 ton with 10 bolt 5 lug now.
07-02-2012, 12:00 AM | #11 |
here ya go
