Old 07-01-2012, 02:59 PM   #1
maynardtruckin
maynardtruckin's Avatar
Question 2000 5.3 overheating
I have 2000 chevy Silverado 1500 4x4 with the 5.3 and it is overheating. When it first started I replaced the thermostat, then the water pump, then the radiator, and the clutch fan and it continues to over heat. With it still overheating I thought that I might have had a bad thermostat, or water pump so I changed them again as well as the sending unit, but alas it still is running hot . I also have tested for a blown head gasket and it is fine. Any help please before I use some DuPont wrenches on it.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 07-02-2012, 07:19 AM   #2
truckdude239
truckdude239's Avatar
Re: 2000 5.3 overheating
you need to verify it running hot useing an ir heat gun or mechanical gague
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-02-2012, 10:56 AM   #3
maynardtruckin
I have.
Chris
Old 07-02-2012, 12:21 PM   #4
truckdude239
what brand is the radiator? my friends s-10 pickup over heated allt he time and his problem was the aftermarket radiator he installed a gm dephi raditor solved his problem not to say its the same thing as yours
David fuller
2000 Tahoe 5.3l 378
Old 07-02-2012, 02:24 PM   #5
maynardtruckin
Its a OE radiator.
Chris
Old 07-02-2012, 10:51 PM   #6
truckdude239
Okay thats weird how doez it run? Only other thing i can thing of is the timing is off?:
David fuller
2000 Tahoe 5.3l 378
Old 07-02-2012, 11:07 PM   #7
maynardtruckin
It runs great but I did notice that the oil pressure has started to fluctuate and it popped a code PO332 which is a low voltage out put on a knock sensor.
Chris
Old 08-27-2012, 09:39 PM   #8
bbchevy
87 Wanna Be K30
bbchevy's Avatar
I know my 5.3 was a little clogged up from dexcool. There was just a bunch of restriction. I bought the best coolant flush I could and it actually made it stop. It used to overheat with the a/c on.
How is yours overheating. Under what conditions? How many miles are on the truck? Does the a/c have clogged fins in front of the radiator blocking air flow?
Does the temp just keep climbing when you start the truck of just spike when you least expect it? Or under a load? Only on a hot day?
-Scott
Was: 1987 V10 Silverado
TBI 350/700R4/208 with 3.42 gears
Is: A wanna be K30
330hp 350/465/205/D60/14FF with 3.73
hydroboost, 4 Core radiator, electric fans, Centerforce Duel Friction, Locker, 6inch Soft ride lift, etc....
bbchevy is offline   Reply With Quote
Old 08-27-2012, 10:26 PM   #9
maynardtruckin
-Scott
It runs fine most of the time till you hook up a trailer and drive. trailer can be empty or full does not matter but if you start to clime even the slightest hill the temp starts to go up slowly but if you let off it cools down. It happens on cold and hot days. As for mileage it is 180,000. NO clogged fines on the ac, or radiator.
Chris
