Old 07-05-2012, 12:09 AM   #1
ArmyCraft
ArmyCraft's Avatar
Lt1 parts in vortec 350
Putting a lt4 in my camaro, the lt1 in it has 90k miles i hydrolocked it and snapped connecting rod 6, well i have all the parts from the lt1 curious what i could put into my brother vortec
I know i can use the cam from what ive researched, but i want to know if i can use roller rockers (1.5 3/8 stud) the roller lifters, lt4 valve springs(bnib) and if i need to use the pushrods (theyre hardend)
And what kind of power gains / power curve would i experience and what other supporting mods would be good for this setup.
Thanks for the info
-Chris
I tear it up...
-90 Chevy 1500 355 edelbrock - sold
-90 1500 reg cab 350 5 speed - current
http://tinyurl.com/c7b7rvy
Plan for the worst , Hope for the best, keep the guys next to you safe, and you'll come out on top. -Hooah
ArmyCraft is offline   Reply With Quote
Old 07-05-2012, 06:42 AM   #2
speedygonzales
speedygonzales's Avatar
Re: Lt1 parts in vortec 350
I used the cam from the Ramjet 350 which has better numbers than the LT1 cam and didn't notice a thing. And I had previously changed springs and rockers and the engine did not like that at all. After the rebuild is when I put the truck cam in.
I do recommend that the injectors be changed in the L31. The originals are garbage. Get the new style available under several brand names actually made by Standard. http://www.summitracing.com/parts/SMP-FJ504
I also rec. cold air intake, headers and cat back. Cut down the baffle on the TB butterfly. With those mods alone, you will get the best bang for the buck.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
