Old 07-04-2012, 06:03 PM   #1
Seafoam72
how do I raise front end on 72 truck 1 inch
I have a 1972 C10 2wd and am looking to raise the front end to level it with the rear. What is a cheap and easy way to do so?
thanks!
Seafoam72 is offline   Reply With Quote
Old 07-04-2012, 07:36 PM   #2
Tinkermc
Re: how do I raise front end on 72 truck 1 inch
you can put blocks in the front springs,CHEAP, you can put in new springs. youcould put bags in the front or air shocks,
Tinkermc is offline   Reply With Quote
Old 07-04-2012, 09:19 PM   #3
CC69Rat
CC69Rat's Avatar
1" drop blocks in the rear = much easier and same result. (assuming youu're ok with it being a tad lower than stock? ) Prob what I'd do .. just sayin.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-05-2012, 12:20 PM   #4
Dano69c10
Dano69c10's Avatar
I saw a raised truck where the owner put a block between the frame and front crossmember to raise it up, but he told me he had to modify the steering components.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 07-05-2012, 12:31 PM   #5
Seafoam72
I just put Power King Super Traxion II's (7 X 15) on, and it looks great. So Im just looking for an easy way to bring the front end up a little. Sounds like the coil spacers may be the way to go. I take it pretty easy on the truck and just want it to look nice.
Old 07-05-2012, 04:59 PM   #6
Seafoam72
I've been looking online and can't find anywhere to order coil spacers for my year model....Any suggestions??
Old 07-08-2012, 12:35 PM   #7
clb1024
clb1024's Avatar
^^^. Spring spacers will give you a stiffer ride up front. When I had my 4wd Pathfinder I used coil spring spacers to give an inch of clearance. Everytime I hit a speed bump(even at low speeds) the springs would basiclly bottom out on the spacers. Atfer about a week they ended up in the local landfill. Just my $0.02 though.
Thanks,
Chris
Favorite quote: "I'm sick and tired of being sick and tired B¡±@h!" - Drunk guy in one of my accounts
Rides:
67 Chevy C10 LWB Stake Bed(in bad shape)
04 Miti Endeavor AWD(wife's ride)
76 Dodge D100 Club Cab(Hand-me down from my Grandfather)
clb1024 is offline   Reply With Quote
Old 07-08-2012, 12:49 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Are you talking easy,... as in not disassembling the front suspension?
Belltech makes a 1" coil spring spacer that goes in the lower a-arm cup,... but the spring has to come out.
Keith
Convert to disc brakes.
Old 07-08-2012, 01:11 PM   #9
DesertCat
DesertCat's Avatar
Thanks,
Chris
X2 I have tried cheap and easy spacers before, every time it was unacceptable. Just a waste of time and money. Rear drop springs would be the way to go IMO
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 07-09-2012, 03:56 PM   #10
Seafoam72
I'm not looking to drop my truck at all, but thank you for your advice.
I have been looking for spacers and couldn't find any. I'll look in to Belltech. If they don't work out I can just take them back out and realign.
thanks!
Old 07-09-2012, 04:08 PM   #11
CC69Rat
CC69Rat's Avatar
Big block front springs maybe?.. that would raise it about an inch
Chad
Old 07-09-2012, 06:29 PM   #12
69gmcc10
69gmcc10's Avatar
Moog spring rates and ride heights
From robnolimit's "make it handle" thread
Moog # 6082 722 lbs/in 6 cyl, and light v-8
Moog # 6542 842 lbs/in std v-8
Moog # 6102 1015 lbs/in bigblock, longbed c.s.
Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102
Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton
69gmcc10 is offline   Reply With Quote
