![]() Join Date: Aug 2011
Rear end question?
I usually hang in the 60's section but I need to know something.
I was told that a 72 c-10 4 x 4 rear end is identical in every way to a 64 rear end, trailing arms and all. True or no? I'm swapping the 64 6 lug for a 5 lug bolt pattern.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
Re: Rear end question?
4x4 69-72 all had leaf spring. I can't answer about trailing arm setup, but seems likely that it could be same.
