Old 07-01-2012, 11:45 PM   #1
overtimeracing
overtimeracing's Avatar
203 help
Hey guys...I bought an unfinished project and am in the process of finishing it. The truck is a 74 frame and a np203. I couldnt find a shifter or linkage so I bought one on ebay. Below is a pic of what Im starting with. what is the aluminum linkage, and do I use it? Thanks in advance for your help!!
Why...Why...Why...Can't I leave anything alone???
overtimeracing is offline   Reply With Quote
Old 07-02-2012, 11:57 PM   #2
overtimeracing
Re: 203 help
Puh-leeze???
Old 07-03-2012, 07:13 PM   #3
75chev4x4
75chev4x4's Avatar
Re: 203 help
Where exactly is this on the case?
75chev4x4 is offline   Reply With Quote
Old 07-03-2012, 08:56 PM   #4
oldgoalie
Re: 203 help
203 t-case have a shifter box bolted on to the top of the t-case with a couple of bolts where it mates to the trans. From that box there should be 2 adjustable rods that go to the t-case and attach the the arm you show in your pic. There should be another arm bolted on the small threaded shaft shown in your pic. One of the arms is for in and out of lock and the other is for in and out of 4 wheel. You will need the complete shift box assy or make your self a 2 lever set up some how.
oldgoalie is offline   Reply With Quote
Old 07-03-2012, 09:17 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 203 help
my 78 np 203
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-06-2012, 09:51 AM   #6
overtimeracing
Re: 203 help
Thanks for the replies, and definitely the pics! I wasn't sure I was going to be able to use the aluminum piece on there, but it looks like I can! I've got a used shifter coming from eBay, so we'll see how it goes! Thanks again!
