Old 07-05-2012, 06:09 AM   #1
blazercrazy70
blazercrazy70's Avatar
Lowering 72 C-10 any suggestions
Any suggestions on lowering wanting to drop just a bit nothing drastic on a budget right now would rather just use springs until i can afford drop spindles looking at CPP any suggestions
blazercrazy70 is offline   Reply With Quote
Old 07-05-2012, 11:27 AM   #2
67chevemall
67chevemall's Avatar
Re: Lowering 72 C-10 any suggestions
bag the back (if you have coils) and cut an inch off the front springs. done
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-05-2012, 11:34 AM   #3
CC69Rat
CC69Rat's Avatar
Jeep TJ springs will work in the back and it gives you a decent drop, but I hear it makes hauling a challenge (really soft) .. yes, you could cut a coil out of your front springs but remember when you cut the coil it changes the spring rate too. What I'm saying is I wouldn't measure the length of the unsprung coil, then cut "2 inches" .. because the drop will be more than you think. One turn out of the spring (full turn) will give you at least 2" if not more. People do it all the time. It's a lot of work too.
Drop spindles are the way to go. It keeps all the geometry and alignment, shocks, etc. pretty much the same.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-05-2012, 12:18 PM   #4
68Stepbed
68Stepbed's Avatar
ECE for one stop shopping and the best quality components.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-05-2012, 12:39 PM   #5
CC69Rat
CC69Rat's Avatar
I heard a lot of complaints about CPP Customer Service when I bought my stuff, so I went a different route. ECE has some good stuff too. I hear Stan is the man to talk to. I found a little better pricing with McGaughys though.
Chad
Old 07-05-2012, 01:01 PM   #6
Malamute
Malamute's Avatar
What was the difference you found between McGaughy's and ECE? I really wanted to keep my truck 6 lug and avoid going with disk brakes but I can see that there is no way to do that if I use drop spindles. If I upgrade to disks I might as well go 5 lug as there are many more wheel options.
Malamute is offline   Reply With Quote
Old 07-05-2012, 01:18 PM   #7
CC69Rat
CC69Rat's Avatar
I did the McGaughys big brakes front and rear, .. modular spindles, etc.
P/N 63148 and 64203. My truck is a 70, so you might check me on these to make sure it would work with your 72.
Actually POL sells a 6 lug disc setup I believe, and I think you can get dropped spindles. Nate's truck is 6 lug disc with spindles if I'm not mistaken.
Chad
Old 07-05-2012, 02:25 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Best, least expensive way in your case would be to cut one full coil off of your front springs. This will give you a 2"-2.5" drop. If you have coils in the back use a 2" drop block. If you have leafs, remove a few leafs to drop it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-05-2012, 03:27 PM   #9
mtnbikeman
+1
mtnbikeman is offline   Reply With Quote
Old 07-06-2012, 12:28 PM   #10
Malamute
Malamute's Avatar
I don't believe you are running 15" wheels though are you? I can't run stock steelies with drop spindles and disk brakes if I'm not mistaken. Sorry for the hijack OP.
Old 07-06-2012, 12:45 PM   #11
CC69Rat
CC69Rat's Avatar
No, 17"+ required.
Chad
Old 07-06-2012, 12:49 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I have 2.5" dropped spindles and disk brakes. No issues with either 15" rallies or 15" steelies. If using steelies, I believe you need ones from 71-up to accomadate the disk brakes.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-06-2012, 12:53 PM   #13
Malamute
Malamute's Avatar
Thanks. My rally's will work, the steelies I just picked up from a '69 will not I guess.
Old 07-06-2012, 12:54 PM   #14
CC69Rat
CC69Rat's Avatar
.. just making sure.. 17" or larger wheels on the McGaughy's kit.
I agree with Zepp, 71-72 dropped spindles should be fine on disc brakes and 15's.
Chad
