07-06-2012, 11:08 AM | #1 |
Ignition Switch Help
Hey Guys, hope you don't mind me wandering over from the 60-66 side...
My ignition switch has the following positions, lock, unlock, run, start. Once I turn the key from lock to unlock I can start and stop the engine with whatever will turn the switch, even a dime for instance! What I don't have is an Accessory position on the switch, and from all accounts, a 60-66 switch just does not have an ACC position. Here is my question: Do your 67-72 dash mounted ignition switches have an ACC position, if so what year? If I can get a dash mounted ignition switch with an ACC position, I would like to try and make it fit. Thanks in advance for the input, appreciate it!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
07-06-2012, 11:10 AM | #2 |
Re: Ignition Switch Help
My 68 does not have a acc position either
Posted via Mobile Device |
07-06-2012, 11:16 AM | #3 | |
My Mom grew up there!
07-06-2012, 11:32 AM | #4 |
my 70 has an acc position
07-06-2012, 11:35 AM | #5 |
07-06-2012, 11:35 AM | #6 |
Oh, good to know. There is an antique chevy parts dealer not to far from me, I will go see them and compare the switches to see if I can make one work.
Thank you very much for the input!
07-06-2012, 01:15 PM | #7 |
The Older Generation
Accessory position was added sometime during the 1968 model year on trucks. If you get one for a '69-'72 you should be good to go. As far as fitment, you will just have to try one. LockDoc
07-06-2012, 01:42 PM | #8 |
Thanks, I checked and "Antique Chevrolet Parts" (20 mins from me) have them in stock, I can compare for fitment, and decide from there.
