Old 02-18-2012, 05:18 PM   #1
djunkie
djunkie's Avatar
Lowering question
I want to lower my '87 more. Right now it's got I believe lowered spindles up front and longer shackles in the back. I was planning on cutting a half a coil off the front to get it down another inch and doing a flip kit in the back. My question is, do I need to reinstall the stock shackles in the back when putting on the flip kit? Also, how critical is the c-notch? Will I be hitting frame without it? Thanks.
djunkie is offline   Reply With Quote
Old 02-18-2012, 05:50 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Lowering question
You don't need to go back to the stock shackle but you should. And yes, notch it! If you dont notch it you'll be about 1.5"-2" from the frame with the axle. That's measuring off the stock shackles. You'll have to remove the factory bump stop and bracket that is riveted to the frame in the rear, but if you notch it you'll be cutting that part out anyways.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-18-2012, 06:06 PM   #3
djunkie
djunkie's Avatar
Is there another option for bringing the back down more without doing the flip kit?
Old 02-18-2012, 11:11 PM   #4
lilpoindexter
lilpoindexter's Avatar
My 1/2 ton short stepper flipped truck axle tube is 3" from frame (less the hideous factory bump stop bracket). I put a little mushroom tip bump stop on it. The leaf spring pack is stock. Even when I helped a friend move, my axle didn't touch.
lilpoindexter is offline   Reply With Quote
Old 02-18-2012, 11:49 PM   #5
1beatnik
1beatnik's Avatar
I bought a multi-leaf dearched and used a shackle and hanger kit, its low, but I didnt notch my frame. Oh yea its my daily driver other than winter, and it hauls and drives fine.
1beatnik is offline   Reply With Quote
Old 02-23-2012, 06:30 PM   #6
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
cut it you puss....
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 02-23-2012, 06:54 PM   #7
djunkie
djunkie's Avatar
Originally Posted by Cole Trickle View Post
cut it you puss....
I'm gonna need to find some stock shackles for the back. I think it'll be too low with the longer ones I have and the flip kit.
Old 02-23-2012, 06:56 PM   #8
Cole Trickle
C-10 Club Member
look in the used section or ask around. gotta be a ton that will just find a trash bin
Old 02-23-2012, 07:03 PM   #9
djunkie
djunkie's Avatar
I think Jimmy may still have his from when he lowered his '85. I just really don't feel like tearing the truck apart right now to be honest.
Old 02-23-2012, 09:31 PM   #10
slinginrods
slinginrods's Avatar
Flipped mine never hits,used 13.00 spring perches welded em to the axle and used front shocks in the rear.
slinginrods is offline   Reply With Quote
Old 03-18-2012, 10:05 PM   #11
djunkie
djunkie's Avatar
Well just an update. I installed the flip kit and put stock shackles back on it. Thing is on the ground. I plan on doing a c-notch but IMO this went lower than it should have. I have about 1" till it hits frame right now. Other trucks I've seen with a flip kit aren't this low. I'm thinking I have some really wore out leaf springs as its super soft in the rear too. For now I put a set of air shocks on it and it really helped. But I'm thinking I need new leafs. Any recommendation on where to get some? I have the 4 leaf pack with an overload leaf in there making it 5 total.
Heres a pick of it without the air shocks and then one with the air shocks aired up.
Old 03-18-2012, 10:14 PM   #12
lanconcj
lanconcj's Avatar
I think it looks perfect.
lanconcj is offline   Reply With Quote
Old 03-18-2012, 10:33 PM   #13
djunkie
djunkie's Avatar
In which picture? Its about 1 1/2 inches higher in the second pic with the air shocks aired up. Thats where I want it. But I really don't wanna rely on the air shocks. I'm wondering if a new set of leaf springs will bring it up a bit.
Old 03-18-2012, 10:35 PM   #14
cochino12
It followed me home?
cochino12's Avatar
bell tech makes a shorter shackle which will raise it back up an inch or so. Looks great in the second picture
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-19-2012, 04:48 PM   #15
DREAMER1
DREAMER1's Avatar
You could always try the local salvage yard for leafs. It's always (most always) trial and error. Your truck may have hauled alot more than others making the leafs softer. When I did my front I was rubbing like crazy. I installed new shocks and I only rub when I hit a bad pothole or something.
IMO looks fine the way you have it now with the air shocks.
DREAMER1 is offline   Reply With Quote
Old 03-19-2012, 05:04 PM   #16
djunkie
djunkie's Avatar
I like the stance with the air shocks also. I'd just like to not have to use the air shocks to bring it up to that level. I'm thinking a new set of leaf springs should bring it up a bit. Then I'll just use the air shocks for if I ever plan on loading something heavy in the bed.
Old 03-19-2012, 11:40 PM   #17
Hulk Will Smash
Hulk Will Smash's Avatar
As I read through this thread the first thing that comes to mind is "Hotboat is a magazine too?!"
And so I'm not completely useless my R30 has a flip kit without a c notch and man when it hits, it's Loud!!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 03-21-2012, 12:09 AM   #18
djunkie
djunkie's Avatar
LOL!!! Haven't heard that one in a while. Had some good times on that website.
Old 03-21-2012, 01:10 PM   #19
Hulk Will Smash
I saw a couple familiar names and was like "where have I seen them before?" I'm still on Riverdave's as well. Really dig the look of your square by the way. Keep up the good work!
Old 03-21-2012, 01:40 PM   #20
djunkie
djunkie's Avatar
Thanks. What was your screen name back in the Hotboat days?
Old 06-17-2012, 03:38 PM   #21
Ford Assassin
Ford Assassin's Avatar
What part number are those air shocks? My ride height is perfect after my axle flip, I just want them to level out the rear when towing my camping trailer.
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-06-2012, 01:00 PM   #22
made2drag
made2drag's Avatar
go to a parts store like autozone and buy a lift shackle. in stall it and your done. they are shorter than a stock shackle and should lift it 1-2 inches. i got 3 1/2 inch drop by just pulling leafs....kept the main one and the 3rd longest one on my k5/jimmy.
made2drag is offline   Reply With Quote
Old 07-06-2012, 01:16 PM   #23
grs
Mine was lowered when I got it. It was not C-notched. The left rear shock would bottom out. It has shorter shocks I think. I C-notched it myself. I did not take the bed off to C-notch it. I had a bracket made to reinforce the frame area. Watch out for wires on the drivers side. You will have to bend the brake line out of the way on the passenger side.
grs is offline   Reply With Quote
Old 07-06-2012, 03:10 PM   #24
made2drag
made2drag's Avatar
man thats a sweet c notch. very heavy duty....overkill is always good!
