07-08-2012, 11:29 AM | #1 |
Exhaust problems, advice please...
Ok, I disconnected the passenger exhaust manifold from the block and pipe, to paint the engine. Now that's done and the exhaust manifold is bolted back on the block, I can't seem to get the exhaust pipe back on (one stud seems to be crooked) so, the triangle plate (bear with me, not sure what its called) will not fit back on under the heat riser. What am I doing wrong here?
And as always many thanks in advance for advice. Getting too much attention starting up like this, lol. Also, cracked off my temp sender on the block, didn't work anyway. How difficult is it to replace? Where to find a quality replacement? 84 305/350 dual straight pipes Posted via Mobile Device |
07-08-2012, 01:00 PM | #2 |
Re: Exhaust problems, advice please...
Lucky you usually the studs that connect the pipe to that manifold are frozen enough to snap every time. So I guess its hammer time ( haha) and hour local auto parts stir can get you a new temp sender
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-08-2012, 01:05 PM | #3 |
do you still run a y-pipe?.....if so try lossening the nuts on the driver side that hold the pipe that may give you some slack on other side.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
07-08-2012, 01:10 PM | #4 |
No y pipe, two single straight back pipes. Thanks, guys.
07-08-2012, 06:43 PM | #5 |
78K & 79C Jimmys
if you can unscrew the temp sender your only gona loose a bit of green if your quick
I use brass nutz they won't rust up on exhaust
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
07-08-2012, 10:11 PM | #6 |
well try and remove a hanger, just something to yeild you a little slack
07-08-2012, 10:29 PM | #7 | |
78K & 79C Jimmys
would loose fitting the manifold to the pipe then to the head is it bad like mine was,could crud/rust be cleaned out,bending the stud threw
07-09-2012, 12:41 AM | #8 |
why dont you try and hook the pipe up to the manifold first losely, then try to the block.
it might make it easier to move the manifold to the pipe to alighn the bolts. |
07-09-2012, 10:26 AM | #9 |
^ tried that was actually harder. Going to just break the crooked stud off, and connect. As its just temp until I get some ram horns.
Many thanks to everyone for their time/advice. Posted via Mobile Device |
