Old 07-09-2012, 10:51 AM   #1
c10 custom
starter solenoid question anybody
hi guys i have a 1979 chev truck and i have a power probe and the small wire on the starter solenoid i have no positive 12 volt power at the wire when the key is on i have a negative power through my power probe and when i turn the key to run the negative power goes out on the power probe wondering if it could be the ignition switch i have headlights and the gauges do flicker when the key is turned on any help would be great
c10 custom is offline   Reply With Quote
Old 07-09-2012, 11:37 AM   #2
rs72z
rs72z's Avatar
Re: starter solenoid question anybody
Only time you should have 12 volts to the small terminal is when the key is turned to the start/crank position. Is that what you meant?
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 07-09-2012, 02:19 PM   #3
c10 custom
yes that is what i meant i cant figure this one out
