Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-29-2012, 06:20 PM   #1
1774btcrew
1774btcrew's Avatar
FS completely gone through manual/floor shift tilt steering column with key
This is a manual floor shift tilt steering column with key for the 78-83 trucks. It will work for 1978 and earlier with the correct intermediate shaft(I have this as well for an additional $20). When I purchased this steering column the lower collar that meets the dash bezel was cracked and missing pieces. To repair this I had to COMPLETELY disassemble this column. I replaced the broken collar, cleaned and regreased everything, and put loctite on the tilt mechanism bolts before carefully putting everything back together. This now works as new with no play. If you are familiar with these at all it is VERY time consuming and involved to take these completely apart and reassemble them correctly. For this reason I want $200 FIRM for this NOT including shipping.
1774btcrew is offline   Reply With Quote
Old 07-02-2012, 06:39 PM   #2
Chevylongbed
Re: FS completely gone through manual/floor shift tilt steering column with key
does it fit on 1987 ??
1987 Chevy C20 LWB Stepside
2009 Mercedes-Benz C63 ///AMG
2013 Lexus LX570
Chevylongbed is offline   Reply With Quote
Old 07-02-2012, 06:41 PM   #3
1774btcrew
1774btcrew's Avatar
No it won't work for your truck as the wiper switch is on the column on an 87 and on the dash for this style.
Old 07-11-2012, 05:33 PM   #4
1774btcrew
1774btcrew's Avatar
ttt
Old 07-17-2012, 04:09 PM   #5
1774btcrew
1774btcrew's Avatar
ttt
Old 07-20-2012, 08:53 PM   #6
m22muncie
m22muncie's Avatar
If you still have this in a month I may be interested. Im flirting with buying a 79 Jimmy I may convert from auto to a 465. If nothing else a bump for you.
70 Chevy Custom 10 400SB, Tremec TKO600, 3.73 posi. LWB hope to chop frame and have it short soon!
71 GMC LWB in the works of getting going for the first time since 1996
m22muncie is offline   Reply With Quote
Old 07-20-2012, 09:56 PM   #7
1774btcrew
1774btcrew's Avatar
Thanks for the bump! With any luck I won't have it in a month. I know this is nicer than any of the other ones out there as I personally went completely through it!
Old 07-20-2012, 10:14 PM   #8
weaintscared
weaintscared's Avatar
will this work for a 69-72?? if so how much shipped to 29150
weaintscared is offline   Reply With Quote
Old 07-20-2012, 11:40 PM   #9
1774btcrew
1774btcrew's Avatar
Sorry it won't work for the 67-72 trucks.
Old 07-21-2012, 11:13 PM   #10
weaintscared
Wish it would have worked I sure need one
