12-09-2011, 08:22 PM | #1 |
trying to drop rear end of my 66 c10 septside long bed any ideas?
hi im new on this forums and im building a 1966 c10 septside long bed, i already dropped the front end but i have no idea to drop the rear end any ideas please!!!! looking for the easy way an cheap too
12-09-2011, 08:42 PM | #2 |
Re: trying to drop rear end of my 66 c10 septside long bed any ideas?
How far are you looking to go down? new coils and shocks run around $150 and you can go 4" with out too much work
12-09-2011, 09:22 PM | #3 |
i have 20' on it, and i will like to drop at least 4 to 5' did you have pic ?
12-09-2011, 10:15 PM | #4 |
2" lowering blocks w/4" drop coils for 6" rear drop. Get some shock relocation brackets for more shock travel & better shock angles. At 6" rear drop you'll also need an adjustable Panhard bar (the longer the better).
12-09-2011, 10:21 PM | #5 | |
I know it isn't the best picture without a bed or front end on it, but hope this helps |
12-11-2011, 12:35 AM | #6 |
3" drop springs in front and 5" springs in the rear. I have the adjustable pan hard bar out back and it made a big difference. I did not get shock relocation brackets but will. I did not need to notch my frame, I have heard it both ways about that. I want 2" blocks out back and 2" drop spindles up front soon.
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
12-11-2011, 01:46 AM | #7 |
nice truck i like the flames, thanks for the advice i will dropped like that, any ideas of convert my small rear window to a big window i saw one last month in a carshow and the guy say he made it ?
07-11-2012, 11:54 AM | #8 | |
www.classictrucks.com search tech for 60-66 chevrolet c10 small to big-window hth |
07-11-2012, 04:52 PM | #9 |
I have 4 inch drop coils and a 1 inch blocks on my 62. I have a adjustable Panhard bar but did not relocate my shocks and was not planning on it.
07-11-2012, 10:30 PM | #10 |
How about using jeep tj coils...I hear they will lower the back somewhat.
