#1 | |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today!
Fired her off today. Mud daubers filled up the hard line between the tank and the new fuel pump. We found out because I wasn't getting gas (duhhhh),and I had installed a fuel pressure gage at the carb... ,,,No pressure. Good news/Bad News: The motor mount lined up after we removed it and the bracket to put in the "worthless rubber plug thing"; Good News: The "worthless rubber plug thing" held; Good news: Gas tank didn't have to come out; Good news: After much fiddling, the 350 is a runner; Bad/Good News: Failure of another freeze plug at the back of the block; Bad news: Tranny still leaking from the shifter shaft after a new seal install; Bad news: Tac didn't get wired correctly....My Bad, as they say in the hood; Good News/Bad News: Trans is coming out to get a good shot at no-leakee; Good News/Bad News: Motor's coming out to install all new proper freeze plugs. Undo a years' work because I was too stupid to: 1: Put in new freeze plugs while the motor was out; 2: Get my arms around the TH350 leaks properly. I just did seals and a new pan gasket. They can leak from many other places, Boys and Girls. Trans fluid, gas, coolant all over the shop floor. One fluid at a time, over and over again. More good news: The fresh engine oil stayed inside the motor. For now.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
LOL ! you have the right attitude , don't sweat it , just take some more time and fix whatever you can whilst the engine is out .
Most of my vehicles come from junkyards , backyards or barns so I know the mud dauber wasp nest issues well ![]()
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
