#26 | |
VA72C10
![]() Join Date: Mar 2008
Re: Speedwarning tach dash with wiring and buzzer choose your options!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#27 |
Carpe manana
![]() ![]() Join Date: Dec 2010
No worries I appreciate the pics. I don't see the vac gauge/vac lens. 80lb oil gauge? OEM printed circuit? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#28 | |
VA72C10
#29 |
VA72C10
Here are the rest of the pictures. The printed circuit has no burns but does have some separation as you can hopefully see in the picture holding it to the light. I personally would use a new reproduction since the circuits are 40+ yrs old.
#30 |
VA72C10
Here is the vac lens (new). My only other isn't up to par with the rest of the dash. I do have another good original printed circuit without burns or separation but is was scratched at some point (likely removal from the truck) so its not perfect either.
#31 |
VA72C10
The white circuit is made in the usa. The green imho looks better (not that it is seen) but is an import
#32 |
Carpe manana
Looks great. I would defer to your judgement on the printed circuit and use a repro if you think best (USA repro). If OK with you I'd send half now half when complete for total of $750 shipped on the tach/vac s/w 80lb oil gauge cluster all OEM gauges with buzzer and harness. Even though I'm sober now
#33 |
VA72C10
Half now half when complete will work fine. I don't have any of the csm panels so its best to go direct to him so you don't pay shipping twice unless you want me to install the bezel w/ adjuster knob. The bezel is 95 and glovebox insert is also 95 (plus shipping) so it is 190 plus shipping for those. If I'm cutting the bezel id need 25 mainly because of the risk when cutting that hole. I cut the woodgrain first with a new utility blade then drill the hole through the plastic bezel. Pm sent with payment info.
#34 | |
Carpe manana
