Old 07-13-2012, 12:00 PM   #1
lucifer
lucifer's Avatar
Cool Burb spare.
Are these spare tire carriers common on Suburbans??
Name:  Dan '65 Surburban 005.jpg
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
Old 07-13-2012, 12:14 PM   #2
65sublime
65sublime's Avatar
Re: Burb spare.
Lucifer,
My '65 came with an "under the bed" carrier and back third of gas tank notched to clear spare.
65sublime is offline   Reply With Quote
Old 07-13-2012, 12:59 PM   #3
hd74
Re: Burb spare.
my GMC is under and gas tank is made for it but i have a towing hitchj is in the way preventing use.
hd74 is offline   Reply With Quote
Old 07-13-2012, 01:45 PM   #4
1963c-10
1963c-10's Avatar
Re: Burb spare.
I dont own a burb, but Id prefer the in truck spare. Same way I have the fender mounted spare on my 63. Just dont like crawling under them...seems my flats come in the worst weather and least opertune places.
1964 Short bed trailer
Old 07-13-2012, 01:47 PM   #5
64fleetside
Re: Burb spare.
My burb has a similar setup.
64fleetside is offline   Reply With Quote
Old 07-13-2012, 09:06 PM   #6
PastJoysandToys
PastJoysandToys's Avatar
Re: Burb spare.
On my 1965 Burb K-10 4x4 it is under also.
PastJoysandToys is offline   Reply With Quote
Old 07-14-2012, 02:47 AM   #7
MusicMan70
MusicMan70's Avatar
Re: Burb spare.
PJT, That's a Sweet Burb.
My 61 came with the spare under the bed as well. You had to crawl under and drop it down off that cross bar-mount(?). My intention was to move it inside, but I didn't want to lose the interior space. I added a tire hoist to mine to eliminate the crossbar support.
As 1963c-10 stated; this can cause problems if you get a rear-tire flat back there or in situations where getting to the spare is unsafe. This chain-hoist came off of a 1987 Nissan truck. I may move it back to the interior later.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-14-2012, 03:32 AM   #8
MikeS.
MikeS.'s Avatar
Re: Burb spare.
Here is the mount on mine, a home made POS that I don't like. Unfortunately they welded it right to the sheet metal. So id I remove it it'll still look crappy.
OP, I like yours much better. I also like the chain hoist idea.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
