Old 07-15-2012, 07:30 PM   #1
hammerdog57
hammerdog57's Avatar
Pics of transmission coolers
Looking for pics of transmission coolers on 55-59s that are running the stock radiator. Also looking for coments on how well they cool and what trans temps they are running. I have a good stock radiator i would like to use if possible.
hammerdog57 is offline   Reply With Quote
Old 07-15-2012, 09:19 PM   #2
Nordic
Nordic's Avatar
Re: Pics of transmission coolers
This what I used. a B&M cooler.I am running a 350/350. I haven't been on the road yet but everythings seems ok running here.
Nordic is offline   Reply With Quote
Old 07-16-2012, 08:21 PM   #3
hammerdog57
Thanks for the pics. Do you have the part number for the cooler you bought? Did you install a trans temp guage?
Old 07-17-2012, 10:40 AM   #4
Nordic
Nordic's Avatar
It is a B&M 70266
Old 07-17-2012, 11:21 AM   #5
LDO
LDO's Avatar
Post #29 of my build thread. I've had no problems with it so far.
LDO is offline   Reply With Quote
Old 07-17-2012, 01:15 PM   #6
OrrieG
OrrieG's Avatar
I used a small condensing unit out of a commercial refer. From 85 to 2000 it was mounted in front of the radiator and worked with no problems. This time I am putting it under the passenger step. I left enough room for a thin electric fan if the temps get out of hand. I put in a tee to monitor the temp at the output line before the cooler. Because the frame, transmission, etc. flex so much off road I use hose connections between the hard lines and transmission.
Old 07-17-2012, 06:44 PM   #7
hammerdog57
I have a 11"x11" by 1.5" oil cooler out of a class a motor home i am thinking about using. I would have to move radiator in from support about a 3/4" to be able to mount it in front of radiator to clear cross bracing.
Old 07-17-2012, 07:09 PM   #8
hammerdog57
What temp has trans been running?
Old 07-17-2012, 10:10 PM   #9
49bowtie
It's not quite what you were after, but here is a Fuel/Air heat exchanger from an USMC F/A-18. I have several work related "easter eggs" incorporated into my old truck. We would change these out when ever the fuel started to run hot on the jet. They cost Uncle Sam $27,349.61 each, but seems to keep my tranny fluid nice and cool.
49bowtie is offline   Reply With Quote
Old 07-18-2012, 01:44 AM   #10
Kim57
Kim57's Avatar
That is real cool. I'd love one for mine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-18-2012, 07:47 AM   #11
LDO
LDO's Avatar
Didn't know these were 'consumable'. I though Poweline always had to turn those in to get a new one....tricky tricky.....
Old 07-18-2012, 10:50 AM   #12
mknittle
mknittle's Avatar
must be a evaprotive cooler
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 07-18-2012, 03:07 PM   #13
49bowtie
SM&R code of PAOZZ, Dispose of at unit level. No turn-in required. Got me worried, and had to go pull up the pubs on NATEC to double-check. We wont talk about the dozens of cruise boxes filled with parts and PEB, stored in my garage during inspections. That's why I love working on this old truck. No rules or pubs, if I think it'll work, I try it and see if I like it.
Old 07-18-2012, 03:25 PM   #14
LDO
LDO's Avatar
Copy all. Been there, done that for sure. If you had a truck in the parking lot during inspections, that's where the stuff was at. Also, being in AVI, we had a vault. EXEMPT from the eyes of the inspectors...
Let me know how you like it.
Old 07-18-2012, 03:35 PM   #15
solidaxel
solidaxel's Avatar
How about the one in the bottom of the radiator ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-18-2012, 03:37 PM   #16
solidaxel
solidaxel's Avatar
I guess the stock rad. did not come with a cooler, sorry I did not read the full comment !
LS 3 4L70E
