Closed Thread
Old 07-17-2012, 03:42 PM   #1001
55metalmonkey
Re: What Did You Do With Your Truck Today ?
Spent a week getting my truck lightly bolted together and moveing under it's own power..... just enough to tease me into dreaming of the day it's driving down the road complete.
only punched the gas once to check out what it has for motivation
Then I drove it onto a trailer and towed it out to my buddies place for final body work and paint ... just a little bit closer to being finaly done
55metalmonkey is offline
Old 07-17-2012, 08:58 PM   #1002
low67chevy
picked up my disc'd corp 14 for my truck and taking the cab off the frame this week
low67chevy is offline
Old 07-17-2012, 09:15 PM   #1003
mknittle
mknittle's Avatar
I cut the parts to make the floor cross sills and started on the fixture. then had a mishap with the sander and ended up with 5 stitches.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 07-18-2012, 04:19 PM   #1004
cheapoheapo
bled the new brakes and got it back on 4 wheels have 4 wheel disc new cpp setup the heat ran us out of the shop early afternoon or we would have stayed longer wife got to hear 350 start for the first time today she said its radical its not just loud with open headers:-]
cheapoheapo is offline
Old 07-18-2012, 04:43 PM   #1005
OrrieG
OrrieG's Avatar
Must have been out of duct tape... Glad you are intact enough to post!
OrrieG is offline
Old 07-18-2012, 04:49 PM   #1006
mknittle
mknittle's Avatar
Thanks Orrie, no duct tape or staples looks like I need to go for supplys.
Mark
My GMC build.
mknittle is offline
Old 07-18-2012, 08:09 PM   #1007
crossfire84
crossfire84's Avatar
cut running board brackets off donor truck, i should of checked for yellow jackets first.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline
Old 07-18-2012, 08:54 PM   #1008
la hi
I did a lot last week. First I made it to the inspection station and passed. I had the muffler guys clean up my exhaust system that has 2/ 1/2" glass packs from the hooker headers, and they added two more 18 glass packs - 2 1/2" id at the end of the tail pipe and now it sounds great.
I installed the leather electric bucket seats I bought in CA and they fit me!!
I installed front gabreil shocks and the front end settled down!
I now have 70 miles on the new 454 and I am learning how to drive a 57!
life is good!
la hi is offline
Old 07-19-2012, 12:58 AM   #1009
OrrieG
OrrieG's Avatar
Finished up the front turn signal retro fit and figured out some wiring routing. Learned that you take a 1157 bulb with you and try it in the aftermarket sockets to make sure it fits before buying. The first one I got did not have the recesses for the bulb pins deep enough.
OrrieG is offline
Old 07-19-2012, 12:39 PM   #1010
wayne4252004
wayne4252004's Avatar
Took off the tires and rims to be sandblasted and painted.
wayne4252004 is offline
Old 07-19-2012, 06:21 PM   #1011
crossfire84
I put my new borgeson steering shaft and joints on today.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-19-2012, 08:20 PM   #1012
Johnny49
Just took some pics to help pass the time until I have the $$$ I need for the brake drums and front bearings. Then we'll finally be able to put everything on and I can drive this thing for the first time. The drums you see stacked in the background were shot when I tried to have them turned. The bed is hiding on the other side of the cab while I clean up the rear part of the frame...
Johnny49 is offline
Old 07-19-2012, 11:02 PM   #1013
mknittle
mknittle's Avatar
cut the front floor from the seat riser to the toeboard out. I could have just patched it but it will look cleaner this way. The plan is to make a frame out of fabracated sills from 12 guage and 1" square tubing.I made a fixture for the sills earlier this week. and today I finnished up a fixture that uses some holes in the fire wall and has A bolt thet contacts the frame on both sides. That way I will be able to adjust each sideof the cab when I weld the floor sills to the cab. I will post some pics later.
Mark
My GMC build.
mknittle is offline
Old 07-20-2012, 04:39 PM   #1014
OrrieG
OrrieG's Avatar
Made up some grounding cables. NAPA wanted $15 each (inc. tax) for two cables. I rummaged around in my electical connector box and found some battery cable ends, went up into the garage attic and got an old cable with a bad end. Made up these two, short is for bed to frame at the rear next to the rear sill mount, other will run from the battery ground bolt behind the box to the frame near the rear shackle. Will probably add a third from the front clip light ground to the frame too.
OrrieG is offline
Old 07-20-2012, 06:21 PM   #1015
crossfire84
Fitted new old running board brackets to frame, will drill new holes later. My wife wants to go to a car show tonight.
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 07-21-2012, 04:25 PM   #1016
cheapoheapo
shortened a gm column today a wise old gear head said i was just making it hard he was right turned out great i was surprised how easy it was to lose 4" and save a bundle
Old 07-22-2012, 02:01 PM   #1017
hsdropout
took photos..........too hot for anything else..........
hsdropout is offline
Old 07-22-2012, 05:51 PM   #1018
mknittle
mknittle's Avatar
looking good! I know what you mean about the heat I went out and measured my transmission and that was enough!
Mark
My GMC build.
mknittle is offline
Old 07-22-2012, 06:22 PM   #1019
mknittle
mknittle's Avatar
That is one interesting truck
Mark
My GMC build.
mknittle is offline
Old 07-22-2012, 08:14 PM   #1020
LDO
LDO's Avatar
Nice work Orrie, so many folks underestimate the importance of good ground cables and ground points. They end up chasing electrical gremlins for a long time.
LDO is offline
Old 07-22-2012, 08:45 PM   #1021
indynick
indynick's Avatar
I gave mine a bath today. Probably it's first in 16 or 17 years.
indynick is offline
Old 07-22-2012, 10:54 PM   #1022
RINC
RINC's Avatar
Mine got new shoes for the time being .... too hot for mush else.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 07-23-2012, 12:35 AM   #1023
sgtusmc
sgtusmc's Avatar
I started to wash my 53 & 59 today. About 10 minuets into it. I heard what I thought was an IED go off, and ran for cover. My neighbor managed to engage all his airbags in his new 2012 Mercedes-Benz S350 at once. He was trying to hard wire an Xbox 360. I has to stop and come inside. I didn't want them to see me laughing
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline
Old 07-23-2012, 12:38 AM   #1024
low67chevy
well got busy yesterday on stripping her down some more, removed the cab and box and transmission , just have to get the frame on jack stands and start stripping her down to a bare frame so i can start mocking up my 4 link setup and my ride height. I think my frame height is going to be around 47" to the bottom of the frame rail off the ground with 44's so should be nice and low and mean looking when its done! heres some more pics for all of you
Old 07-23-2012, 01:02 AM   #1025
OrrieG
OrrieG's Avatar
Massive garage organizational frenzy this weekend to get stuff ready for a garage sale and get some of the truck stuff off the floor and on shelves. This week is clean the bolts, screws etc for the door hinges and latches and get them installed, tired of messing with them every time I get into the parts box. Too hot for body work or paint, its 11 pm and still 94.
OrrieG is offline
Closed Thread
