Old 07-17-2012, 04:44 PM   #1
67chevemall
67chevemall's Avatar
Question tightning castle nut when ball joint spins??
Help!! What is the trick to tighten the castle nut down on the ball joints when the ball joints spin with ease???????????
Stuck!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-17-2012, 07:05 PM   #2
Axle
Axle's Avatar
Re: tightning castle nut when ball joint spins??
Stick a drift in the cotter pin hole and use a wrench to tighten it, at some point it'll "stick" and you can proceed normally.
Alex.
Axle is offline   Reply With Quote
Old 07-18-2012, 12:07 AM   #3
AustinScott
AustinScott's Avatar
When I did mine I just used a jack under the arm and put some pressure on the ballpoint and caused it to friction wedge into the spindle
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
Old 07-18-2012, 06:12 PM   #4
SCOTI
SCOTI's Avatar
We just had this happen on a 92 & I use oversized washers to overcome the problem.
Stack them high enough so that there is enough thread to engage the nut but also so that the BJ is immediately pulled into the spindle. It should snug up quickly & then take the nut back off, remove a couple of the washers & repeat until it's seated enough so that it doesn't spin. Pull any remaining washers & tighten to spec + install the cotter key.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-18-2012, 06:25 PM   #5
dhughins
dhughins's Avatar
we had to use a puller and put the screw in part on the end of the ball joint, and pulled the pieces together kinda like a big clamp. be careful not to mess up the end of the ball joint.
dhughins is offline   Reply With Quote
Old 07-18-2012, 09:31 PM   #6
cableguy0
I normally use an impact gun. It spins fast enough to overcome the balljoint spinning. If you dont have an impact you need to pin the ball joint shaft into the spindle.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
