Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-18-2012, 09:57 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
509 2 bolt 400
Looks like i may end up with one of these through some trading . Guessing a 5.7 rod 406 is the motor to build . Looking for 400 SBC stories or opinions . Pump gas bracket motor that will probably end up in the metric Malibu footbrake car .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-18-2012, 10:04 PM   #2
Vortecpro
Re: 509 2 bolt 400
Originally Posted by hotrod 80 View Post
Looks like i may end up with one of these through some trading . Guessing a 5.7 rod 406 is the motor to build . Looking for 400 SBC stories or opinions . Pump gas bracket motor that will probably end up in a metric Malibu footbrake car .
Sounds like a good idea to me.
Vortecpro is offline   Reply With Quote
Old 07-19-2012, 12:29 AM   #3
Rannos
Rannos's Avatar
Re: 509 2 bolt 400
I have built a few of these. Only one ever had a probelm. The last 406 short block I built was originally for my personal truck but the truck was stolen so I traded the short block off. Was a forged internals, balanced setup with flat tops. Guy I traded it to sold it to a customer of his. They put a set of milled heads on it to get 13.1 out of it and a big solid roller. Then tossed on a small kit and first time they sprayed it it lifted the heads. It litterally pulled the head bolts and threads/thread bosses right out of the block. I have sence read that this is common when you push factory 400 blocks to or above 600hp. I'd say it your 550hp or less go for it but if your goning to be getting close to 600+hp I wouldn't waste the money on a factory block when something like the SHP block is so cheap.
Jay
Rannos is offline   Reply With Quote
Old 07-19-2012, 05:42 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 509 2 bolt 400
Good info . I might put a power shot fixed low power plate on it , but i dought it . The plan is consistant and reliable more than all out power . Guessing these blocks dont need to be clearenced and all that mess . Always shyed away from 400's due to wives tales i guess . Should probably put a 5.3 or 6.0 LS in it and be done . Still stuck in the 70's i guess .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-19-2012, 08:40 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 509 2 bolt 400
Been there done that (I hate that phrase) but it fits. Have pictures of the carnage if you care to see.
I'd suggest you not put a buttload of $'s into parts and pieces here. It goes right along the same lines as you don't build a million $ mansion on sand. If your going to spend the $'s on a upper end motor, don't risk it in a stock, production platform. The SHP block is 100times more reliable at the 500+ HP level. And a Little M or Motown for anything above 700.
I think there are a couple other folks in here that have been down this same road.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-19-2012, 10:04 AM   #6
nxtruck
nxtruck's Avatar
Re: 509 2 bolt 400
I concur. Even though I've had good luck with my current motor (509-based 434), if you're planning on making 600 or more, you may want to consider upgrading to an SHP. I've ran a few 509-based motors ( 3 377s, a 421, and my current 434 ) and split the #4 cylinder on one of the 377s with some nitrous. If you just looking for a 500 or so hp bracket motor, I say run the factory crank, a set of cheap 5.7 rods, and a set of budget forged pistons and have at it.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 07-19-2012, 05:18 PM   #7
Rannos
Rannos's Avatar
Re: 509 2 bolt 400
I agree completely... Up to around 500 your pretty safe with a 509. When I started to build my new engine I was debating using the 400 block I have but once I started running into deals on some good heads and valve train I was worried I'd lift the deck or split the main webbing once I started spraying it.
If you did much of the index racing at HMP I am sure you know Gary Sangster. He told me last time I talked to him, he went through 4 509 blocks in two seasons before he gave up and started buying aftermarket blocks.
