#251 |
Re: My '74 build- "Clifford"
#252 |
That looks good man! I like that seat.
Posted via Mobile Device |
#253 |
Loving the interior!
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop |
#254 |
GM Addicted
interior looks good. I like the seat where did you get the material for it. Also can i have the specs on your slots just found a set of 15x10s now i just need 8s for the front. What size tires you running on them??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#255 |
Slots go on anything!
Thanks, Mike!
Brandon, I actually got the insert material from a place that sells material for furniture. The supplier for the upholstery shop I use wanted $ 50 per yard, this was $15. That was a no brainer. On my slots, they are 15x8.5's all the way around. Not sure of the backspacing. Front tires are 245/60, and the rears are 255/70's.
1974 Jimmy- 5.3/4L80e/NP241 |
#256 |
GM Addicted
Oh okay thanks. I thought you had 10s in the back im going to go look at the pair today. The only thing that worries me is they were originally 5x5 and he had a machinest machine them to 5x4.75 so i dont know if i will be able to find the correct uni-lug lug nuts and washers.
#257 |
Looks killer bro!!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#258 |
. Do you still have this truck? If so, any updates? The slots look GREAT on it! . .
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
#259 |
Clifford got sold long ago to a cat out of OK that has done a bunch of suspension work to him. There's a thread on it here somewhere.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#260 | |
. Thanks for the heads up - was able to locate the new build thread using the search feature: http://67-72chevytrucks.com/vboard/s...d.php?t=555918 . .
