IFS Question...
I'm about to acquire a pretty clean '59 Fleetside. Has anybody heard of using a '62 Corvette clip in a truck like this? If so, are there any downfalls? I'm not opposed to cutting it off and using a Camaro clip instead if I have to. Is that necessary? Thanks!
![]() Join Date: Jul 2007
Re: IFS Question...
A 62 Corvette crossmember would be going backwards on one of these trucks as it is basically the same crossmember and suspension as 49/54 Chevrolet Sedans ran.
Most of the kits that use Corvette suspension use C-4 Suspension. Check the thread on the kit Porterbuilt is coming out with for your truck using C-10 truck pieces. The Camaro Subframe swaps are probably the least expensive way to go but you can figure on a couple hundred dollars to the cost because most will need to be rebuilt by now. |
Re: IFS Question...
The '62 corvette clip is not unique to the corvette. It's the same clip used throughout the 50's in the chevy sedans. It's very old technology. I would think a Camaro clip might serve you better.
Hollister Road Co.
Re: IFS Question...
Its the worst of all worlds. Semi Ball Joint King Pin setup.
Re: IFS Question...
Also too narrow between the towers for a Task force truck. The C-1 Corvettes and the 49/54 Chevy cars have a frame similar in width to the AD trucks but the Task force frame is several inches wider at the axle center line.
Re: IFS Question...
too light for these trucks
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
