seat won't move
i removed the seat from my 71, after putting it back in it won't slide. any ideas
thanks jim |
Re: seat won't move
Is it both sides that wwon't move or just the right side? Is the wire conected to the right side ? If so is it tight enough?
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
Re: seat won't move
what wire are you talking about? i have no experience with the seats. i took the seat out to do some work on the truck, when i slid the seat in the garage a rod fell out, thought it was for seat support put seat back in and it wouldn't move. what should i do now?
thanks jim |
![]() Join Date: May 2012
Re: seat won't move
that rod needs to be connected to both sides of the seat, that way both slides work together.....or take two people and move it where you want it and leave it there....you will see under the seat tracks where it goes....good luck...
Re: seat won't move
There is a wire that connects the lever on the left side with a lever that ss under the seat on the right side if you look under the sear you will see an arm sticking out on both side they should be conected with a length of hardened wire if not pull the seat back out and flop it over.
take a look at this: http://67-72chevytrucks.com/vboard/s...d.php?t=417419
Re: seat won't move
thanks guys
jim |
