Re: 94 3500 4x4 gmc. Transfer case wont work?
Does the transfer case actually shift into 4hi/lo? I'm assuming the tcase actually shifts into either one of these ranges but the front doesn't engage. If this is the case its most likely the front differential actuator. It is electronic and they are notorious for failing. You can get a replacement stock type one, or like I did there is and aftermarket cable setup you can convert to so you have a pull cable under the dash to lock the front end in. I believe it is made by posi lock? Can't remember, I got mine through summit though.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
