![]() Join Date: Jul 2012
Factory auxiliary fuel tank
Picked up a '72 Custom Camper, that originally came with a driver side auxiliary tank, but was removed. The filler, which is at the same height as the cab fill, and cover box were still on the truck. I would like to know if anyone has a pick, or possibly dimensions, of these factory tanks.
All Day Every Day '72 C20 Cheyenne Custom Camper http://67-72chevytrucks.com/vboard/s...d.php?t=549132 |
Member #1049
Re: Factory auxiliary fuel tank
I can not help you with dimensions but here are a few pictures.
Awesome! Thank you. Im either going to try and build one, or find a solid used.
I see the fill, the whole for the sending unit, but what are the three smaller wholes? Mounting wholes?
#5 | |
Member #1049
The three little holes are for the mounting bolts. they are long carriage bolts. |
I figured as much. Great pics. Thanks for your help.
![]() Join Date: Oct 2009
Livrat, those are mighty purdy. I mean WOW! Very nice. I don't suppose you would have measurements to share would you?
Member #1049
Sorry to say I did not take any measurements.
I sent the crusty original tank out to a buddy for cloning, he sent back an aluminum work of art, I installed it in the customers truck and tossed the original. |
There is also a lot of really good information on the RPO NL2 aux tank in the assembly manual.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
