Old 07-06-2012, 11:28 PM   #151
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Just an Old Truck"
As was suggested to me, I bent the metal portion of my front brake hoses to help them clear the spindle and ball joint nut. I still need to get banjo bolts, the ones I have are too big for some reason, but I think this will work...
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-07-2012, 11:01 PM   #152
C10_ustacould
Thanks to Hart_Rod the front brake hoses are complete, he came through with the correct banjo bolts. I will bleed and leak check them in the morning. One more thing off the list!
Also worked on engine and gauge wiring today. Just have to keep plugging away at that...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-11-2012, 06:35 PM   #153
C10_ustacould
Need a little motivation, so I was going through old pics. Found one of the ride I had in High School, also a '68 but of the Camaro kind. The first is from around 1991, and the second is from 1998-99... good times! Okay, enough of that, I'm going out to work on my truck!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-24-2012, 06:34 PM   #154
C10_ustacould
Waiting for some parts to come in, so to combat the boredom I had a friend make an adjustment in wheel color... what do you think?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-24-2012, 08:41 PM   #155
Hart_Rod
Hart_Rod's Avatar
Bravo!!!!
Hart_Rod is online now   Reply With Quote
Old 07-24-2012, 08:54 PM   #156
NewType72
NewType72's Avatar
love it!! great choice
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 07-24-2012, 09:25 PM   #157
VA72C10
VA72C10
VA72C10's Avatar
very nice!
Old 07-24-2012, 10:18 PM   #158
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Looks awesome just like that...I would leave the trim rings off.
Old 07-24-2012, 10:27 PM   #159
Low Elco
^^^^this. Looks tight!
Low Elco is offline   Reply With Quote
Old 07-24-2012, 10:30 PM   #160
C10_ustacould
I think you are right, no trim rings for sure.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-24-2012, 10:33 PM   #161
mcbassin
Still Learning
mcbassin's Avatar
Awesome Camaro!
Old 07-28-2012, 09:39 AM   #162
C10_ustacould
Originally Posted by mcbassin View Post
Awesome Camaro!
Thanks, it was a fun car! Completely street legal, I drove it to work on Fridays.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-28-2012, 12:59 PM   #163
68 Four on the Floor
68 Four on the Floor's Avatar
Liking the wheel color..
68 Four on the Floor is offline   Reply With Quote
Old 07-28-2012, 01:54 PM   #164
shawno72
C/10 junkie
shawno72's Avatar
Looking really good....
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 07-28-2012, 02:37 PM   #165
tsali39
tsali39's Avatar
Truck sits well, I like the silver wheels better. Trim rings may fix this!
Eddie
tsali39 is offline   Reply With Quote
Old 07-30-2012, 06:02 AM   #166
C10_ustacould
Not much completed over the weekend other than the drive shaft. It was just way too hot... I did order a new engine management harness from PSI this morning, we'll see if that helps the progress any. lol
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-15-2012, 09:12 PM   #167
C10_ustacould
Updates:
- Brakes filled, bled, and leak checked... so far so good.
- New harness is laid out and I am currently building an ECM mount for under the dash in the glove box area.
- Radiator is mounted, but I have yet to get hoses.
- Trying to figure out what to do with for the air intake system...
That is where I am, I'll give another update as soon as I complete more. Until then here are a few pics of the harness pass through.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-16-2012, 12:32 PM   #168
Portmod7
Portmod7's Avatar
I'm about to do this myself, and was wondering how I was going to get a tight fitting grommet/hole in the firewall and still be able to get my connections on each end of the harness through it.
Yours came out very nice. Did you manage to get a completed harness through that hole, or did you put the wiring through before you put connectors on your harness?
I've tried looking for "reducer grommets" (for lack of a better term), but haven't really had much luck. I also thought of sliding a grommet over the wire bundle before I built the harness, making a large hole in the firewall, and then making a sheet metal cover to reduce the big firewall hole to the small grommet. That way I could still pull the whole harness down the road without any cutting.
I really like your truck by the way. The spirit of my build is very similar.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 08-16-2012, 02:01 PM   #169
C10_ustacould
It wasn't too bad getting the harness through. The hole is 2" and the grommet slides on the main trunk of the harness. It helps to have another person to pull as you feed it through. The harness from PSI is meant to be fed from inside the cab into the engine compartment. The harness was $499 plus shipping and was worth every penny in my opinion.
Any pics of your truck here on the board?
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-16-2012, 03:19 PM   #170
Portmod7
Portmod7's Avatar
Thanks for the info! I'm using a FAST throttle body, and building a MegaSquirt ECU and harness to control it.
No pics yet, I'm trying to get it finished up so I can get some pictures. Hopefully by the end of the year. This is how she sits right now, plus hubs, brakes, and sound deadening inside the cab.
Keep up the good work!
Old 08-18-2012, 04:09 PM   #171
C10_ustacould
A little more progress so far today. Been working on the ECM mount, it's a bit crude but should work just fine. This sequence shows from when I started until the final test fit, just have to scuff and paint it.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-18-2012, 04:10 PM   #172
C10_ustacould
Man, I like that blue and white. Keep us updated with a build thread!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-18-2012, 07:41 PM   #173
C10_ustacould
ECM mount painted and installed, Entropy fan relays and fuses installed...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-20-2012, 01:05 PM   #174
Portmod7
Portmod7's Avatar
Thank you!
I'll have to get my pictures together and see what I can do about a build thread. I've gotten a lot of good ideas and help from the ones I looked at, maybe I've got a trick or two up my sleeve that someone else could use.
Keep up the nice work!
Old 08-20-2012, 10:15 PM   #175
NewType72
NewType72's Avatar
really shapin up Buck great job
- Dylan
(209)-985-7721
